Question about Lexmark X4270 All-In-One InkJet Printer
Cartridge problem of the fax.
I have problem with the fax incoming faxes are not in print form i receives faxes but in blank could u solve the problem. i have recently changed the black cartridge of the machine.
    Sergeant:
  • 390 Answers
Are you saying the fax appears to print but is blank or it does print but is not in a fax form but freestyle with no background format. Changing a cartridge will often upset the apple cart. see if the printheads could do with a clean. Make sure you reset ink level sif your unit does not automatically do this. Try a reset too by turning unit off, unplugging all cables, replugging all and turning back on. Post back if no good.
cheers,
lilacgerry
Posted on Nov 21, 2008
Not receiving faxes
please replace with new original cartridge to solve this problem.
Aug 28, 2014 | Canon ImageClass MF-8050CN Multifunction...
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark X4270 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
