Question about CyberLink PowerProducer 2 for PC
Freezing of Power producer 2 during last phase of DVD file making
With the last DVD I was trying to do, the program freezes on a certain % while completing the last phase before starting DVD burning.
The upload of images and music is OK, the test of the DVD album and movies and sounds seems OK during the preparation phase ...
The process of writng files before DVD burning starts but the program freezes on a specific %.
What can I do to complete the DVD?
Is there something I have to check?
Tank you.
This problem is solved by getting a mor powerful computer, and using same program and windows XP
Posted on Mar 29, 2013
    Novelist:
  • 208 Answers
IF THE PROGRAM FREEZES AT THE SAME POINT EVERYTIME, YOU CAN ASSUME THAT YOUR PROGRAM OR SOFTWARE INSTALLATION IS CORRUPT. TRY TO DELETE AND RE-INSTALL THE PROGRAM AND SEE IT YOU CAN GET A CLEAN INSTALL. REPLY TO ARCLIGHT1217 WITH WHAT YOU FIND OUT!
Posted on Nov 14, 2008
SOURCE:
How to Prevent my Computer from Freezing?
Freezing can have several causes.
A program calls the cpu in a wrong way, or the cpu is overheating, and more possibilities.
1. Overheating: after a certain time of operation it just freezes. Try cleaning the inside of the computer. Be careful for static electricity, which might kill your CPU.
Look at some instruction videos at Youtube.
2. Does it always happen when you start a certain program ?
Then the best thing to do is to install Process explorer and investigate what was happening just before it freezes:
Try this:
http://visihow.com/Investigate_Hang-Ups_on_Your_Computer_Using_Process_Explorer
Good luck investigating,
A.Misset
Oct 18, 2016 | Computers & Internet
220s hangs during reimage
Does it give you an error that it cannot copy certain installation files?
If so then either your Windows install CD/DVD disk has a problem or your hard disk drive has a problem. If I knew what model you have I could give you a link to run diagnostics to determine the issue.
Feb 16, 2013 | Dell Vostro Computers & Internet
Picture freezes while dvd player playing
The problem is in the laser pickup assembly, the stepper motor that moves the laser is sticking on the worm gear or excessive ware on the gear linkage is preventing it from moving.
Mar 14, 2012 | Samsung SWA-4000
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ps3 freezes while playing certain games..i.e. God of War3 and Assassins Creed..What's the problem?
try updating firmware or doing hard reset.
this is a last resort Sony support recommends.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
Apr 09, 2010 | Sony PlayStation 3 Slim Black Console
Copyright Message on Panasonic DMR-ES10-S
certain files are decoded w/ copyright protection not all
Aug 13, 2009 | Panasonic DMR-ES10 DVD Recorder
Windows XP - programs are not opening, some functions (such s downloading email attachments to certain programs) are causing the program to freeze. First, my imaging program didn't work, now IE of...
Backup all your files to a CD/DVD-writable or to a USB memory-stick.
Reinstall Windows from trusted media.
Access "Windows Update" to get all the security patches.
Reinstall your anti-virus software.
Reload your files from your backup.
Jun 04, 2009 | Microsoft Windows XP Home Edition
DVD recording freezes up
Freezing like this is usually a sign of lack of memory.
Ensure all other programs are shut down.
Burn fewer files at a time
Aug 30, 2008 | Roxio Easy CD & DVD Burning
DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
Jul 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
CyberLink PowerProducer 2 for PC Logo
328 people viewed this question
Top CyberLink Computers & Internet Experts
Alli Abiola
Alli Abiola
Peter Dragonetti
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
