Question about M-Audio FireWire 410 External Sound System
I have a MAUDIO FireWire 410 conected to my Acer Aspire Laptop 5570z. It has been running fine now for over a year and only 2 days ago I have a problem. The S/PDIF output light stays on and I can't switch it off, this is causing my microphone to not work, I believe. Can you please help me to switch it off and get my microphone working?
  • daniel875 Nov 14, 2008
    No you sent me to get a MAC driver when I told you it was for Windows, and the our session was closed
  • Juanita Vega
    Juanita Vega May 11, 2010
    i'm the one you talked to in live chat i hope everything went well
  • 685 Answers
I'm very sorry my internet went down and i just got it back up and running
Posted on Nov 14, 2008
    Sergeant:
  • 207 Answers
Daniel,
Since you've been using this unit for over a year without fault, I'm going to assume that you have the right Mic input selected, have the mic connection(s) firmly in their inputs and the gain set properly.
However sometimes accidents happen, so just double check those to make sure that they are indeed still set properly.
According to M-audio's manual for this unit it is NORMAL for the s/pdif's input and output to glow steadily (Even when not in use) and the input to become intermittent when IN use. So it is unlikely that the s/pdif is the culprit here.
Once we have determined that all of your NORMAL settings are still accurate we need to troubleshoot here.
Are there any changes you made to the system about the time that the problem started?
Reinstalled the OS? Installed or uninstalled Audio related Hardware/Software etc......?
Check in the Device manager(if you need direction on how to do so then comment back and I'll describe the procedure)
I'm not sure if this will be under Firewire adapters or under the Sound Game controllers so check each spot. Is there an exclamation mark in a yellow circle next to the devices entry? If so then you have a driver issue
Drivers can be found here. just select your unit and Windows XP SP1/SP2/SP3 depending on which one you have.
http://www.m-audio.com/index.php?do=support&tab=driver
You might try this even if there isn't a driver fault shown.
Right click the driver in device manager and select uninstall. Once this is uninstalled the system will likely ask you to reboot to FINISH the uninstall. Now download the appropriate driver for your unit. After the reboot install the new driver and check to see if it's working
If it Still is not working. Your likely fault is an electrical one. try using a different MIDI or Firewire cable (Depending on how you connect to your PC)
If thats not it TRY a different Mic on your Input
If that STILL is not it then the problem is likely IN the unit itself, Unless your comfortable dealing with high voltage electronics, I think this is where a service department should come into play.
Hopefully you find this helpful, and please don't let your bad experience on the CHATS affect how you feel about Fixya
Any questions you have regarding that may be directed to
premium.support@fixya.com
Hope this helps you
Dave
I have a acer aspire 5570Z, unable to connect online...
Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
If you are using your manufaturers software then try using windows xp (or vice versa)
Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Black Screen on ACER 5570Z
there is a os problem try to run system in safe mode or format it
Jun 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
Need 2 drivers for Acer Aspire 5570Z notebook laptop
Hi there
Go here, select your operating system and then download the drivers you need:
http://support.acer-euro.com/drivers/notebook/as_5570.html
Thanks for using Fixya!!!!
Feb 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Drivers xp for acer aspire 5570z
you can download it from www.acerpanam.com.
Find the driver under these models
Aspire 5570z = Aspire 5570 = Aspire 3680 = Aspire 5580
Apr 09, 2008 | Acer Aspire 5570-2758 Notebook
Drivers for acer aspire 5570z
i need all drivers for acer aspire 5570z driver for win xp
Mar 26, 2008 | Acer Aspire 5500 5570-2609 Laptop
5573ZNWXMi drivers
Aspire 5570z (5573z)
www.acerpanam.com
if you can't find drivers under Aspire 5570z try under Aspire 5570.
5570 and 5570z are same
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Lots of noise when laptop power cord is plugged in
You must be running on pc, or it sounds like you may have a ground loop issue. If you are running a mac, then bus power over the firewire should be enough. If your running on a pc, try getting a pcmcia card with 6 pin firewire ports. If not then your pc laptop will have to power the 410 via ac adapter. That means both should be plugged in tot he wall. Ive gotten that interference before, and gett it on any audio, whether im producing or playing itunes. I find the trick is to reset the 410 via the output window in the top right. It's right above the level knob. Also, try just installing the latest driver, with the 410 disconnected, then launch it from a different file path than the icon.
I still use it for the macbook pro, and its not always top notch. I bought it 3 years ago for 500, and i see what 500 buys nowadays.......MOTU!!!!
Keep me posted.
Dec 08, 2007 | M-Audio FireWire 410 External Sound System
Open Questions:
M-Audio FireWire 410 External Sound System Logo
132 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
