Question about Canon PowerShot A430 Digital Camera
Batteries discharge in 5 shots
I am using a brand new non-rechargebale batteries (Duracell Plus AA Alkaline MN1500) with Canon Powershot A430 AiAF. And after two photographs it gave in. Is this camera going to very expensive to use?
I don't have a solution but I have exactly the same problem. Initially the camera would last for hundreds of shots and now it goes flat almost instantly. I suspect there is a fault with the camera battery indicator.
Posted on Jun 11, 2007
Canon Powershop A430 Digital Camera wont work with new batteries. I tried switching and used both alkaline and some regular ones but it keeps saying the batteries are low. How can I fix this?
If the camera has a lens that extends when you power-on, it may have failed to park completely when power went off, due to the weak battery.
Gently press on the front of the lens barrel to attempt to seat the lens.
Then (with a good battery) turn-on the camera.
If you are currently using the NiMH AA rechargeable batteries, I would suggest you try standard Alkaline AA batteries. They have a bit more voltage than the NiMH and it might make a difference in this case.
If that does not work, you should phone Canon Service and see if they have any suggestions.
I am sure they have encountered this problem before.
Hope this helps,
Feb 18, 2011 | Canon PowerShot A430 Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Display says to change batteries..have done and still says to change batteries
Strange as this solution might sound,m it works; clean the battery contacts in the camera, as well as the battery itself with alcohol. Even a small bit of oxidation, at the current level the camera requires, drops quite a few mvolts, enough for the camera to think your battery is running low.
Anand
Mar 05, 2010 | Canon PowerShot A710 IS Digital Camera
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
A590is camera always indicate low batteries, even with new ones.
Which EXACT make and model of batteries are you using?
There are batteries which will fit, and there are those which actually work. If you're using cheap zinc carbon batteries, market/boot sale fakes, or generic pound store/dollar store batteries then you'll have this problem.
Your camera must use two AA size batteries, either alkaline cells (e.g. Duracell) or NiMH rechargeables. Fully charged NiMH cells will far last longer in your camera than non-rechargeable alkaline cells; according to Canon it's approximately 220 shots for alkalines and 500 for NiMH.
If you're using the correct batteries then the next thing to do is to check that the battery contacts in the camera are clean, bright and grease free, and that the same is true of the batteries. If you're using NiMH's then bear in mind that like all rechargeables the performance drops over time and eventually they need replacing, but they're widely available and not expensive.
Feb 10, 2010 | Canon PowerShot A590 IS Digital Camera
Canon Powershot A470 - asks to 'change battery' every time it is turned on, then turns off immediately. This is so even when new, fully charged batteries (different brands, rechargeable, non-rechargeable)...
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
Jan 08, 2010 | Canon PowerShot A470 Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
Powershot A430 canon camera battery problem
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Aug 08, 2008 | Canon PowerShot A430 Digital Camera
Camera turns itself off while i am using movie mode
Use alkaline batteries like duracell. Digital cameras support only extra duty batteries.
May 04, 2008 | Canon PowerShot SX100 IS Digital Camera
Batteries
Are you using alkaline batteries? If so, consider rechargeable NiMH AA batteries instead. Digital cameras are notorious alkaline battery eaters. By comparison, modern NiMH rechargeable batteries will last much longer per use/charge than ANY alkaline battery (up to 5 times longer). If you don't have them, get them, you won't regret it. Look for a power rating on the package of at least 2,500 mah.
Jan 01, 2008 | Canon PowerShot A560 Digital Camera
Canon PowerShot A430 Digital Camera Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
