Question about HP Compaq nx6310 Notebook
Dvd drive failure cant load os
I wanted to restore to factory settings on my Compaq nx6310 notebook using the recovery diks, after the formating went to half way it reprtedthat the dvd drive had failed
  • 93 Answers
What cause you want re-install your system by the recovery CD? What maessage have you got from screen when DVD had failed? do you have any other partitions in your HDD, which driver e: or f:...
Posted on Nov 17, 2008
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
I got a compaq cq61 notebook with windows 7 OS, and when hitting f11 for recovery it is asking for the recovery disk and i dont have one, i got the recovery partition on the computer and how do i restore...
didnt u make the recovery discs beforehand???? if the option for restore factory settings is shown...then go for it.....it works in my vista....u will have your notebook as it was when u bought it.....but only one problem.....you will lose everything u have on your laptop..as it is formatted...
Dec 30, 2010 | HP Compaq Presario V2000 Notebook
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
How to use reset disc
For instructions, "how to use windows explorer version 8" open Microsoft's link provided; http://www.microsoft.com/windows/internet-explorer/support/faq.aspx
The term you posted. "How to use reset disk". If it’s your intention to restore your laptop, notebook system back to its original factory condition than use your restore CD's. Your Compaq came with a few CD's. One should be labeled Restore CD. Insert the Restore CD into your CD-ROM drive. Restart your notebook.
Follow the on-screen instructions to restore your Windows system back to its original factory settings.
(Warning! By using the restore CD, your personal data/ programs may be erased). If your Compaq is able to load your Windows operating system. Try running Windows System Restore. Pick a date (Past), that your Compaq functioned correctly and allow windows to restore your operating system. (Doing this will not uninstall your data or programs).
Good luck, hope you find this helpful.
Mike
Oct 29, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
HP Compaq nx6310 Notebook PC recovery disc
You can try pressing the F8 key at bootup to get the boot screen, and select the option " use last known good configuation" and press enter. if that dosn't work, you can do the same thing only select SAFE MODE and press enter, an that should get you into windows. then you an go t Start/accessories/systemtools/system restore, and restore th system back to a date before your problem started.
Dec 16, 2008 | HP Compaq nx6310 Notebook
Reformat the notebook with out recovery
you can get all the drivers and utilitys off www.compaq.com.
goto support and downloads.and enter your computer model in the box.
Dec 15, 2008 | Compaq Presario Notebook
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
Factory.settings
According to what you have said, you might have created the Recovery disks after purchasing the notebook.Now you are trying to restore the notebook to factory settings, but they are not working.
Even you have tried to F11 options to restore notebook using the Recovery partition of your notebook.
Let me assist you in this regard.
If the recovery disks are not booting, then we have to check if the issue is with the disks or with the CD/DVD drive itself.
To check that, you need to try to boot with any other OS CD. If the notebook is booting with other OS disks, then the issue is with the Recovery disks itself.
Even F11 option is not working, you have to make sure that D: Recovery is not removed.
For your information, if the issue is with the Recovery disks, then you can purchase the Recovery disks from Hp at very low price.
You can order them from the below link:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=500508
Under
CD-ROM order page - Recovery Discs you can order the place order for Recovery disks.
Aug 09, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq nx6310 PC Notebook Problem
Start your system enter BIOS, under the configuration settings disable SATA NATIVE MODE. Save changes and exit. Boot from the CD format.
Jul 02, 2008 | HP Compaq nx6310 Notebook
Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
Jan 28, 2008 | Compaq Presario M2000 Notebook
HP Compaq nx6310 Notebook Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
