Question about Refrigerators
We have a Food Conservation Centre which ia in excellent condition except for the door rubber gaskets. The model numbers are: ARG 051/PH Ser: 860500353. Here in Menorca the tech support for this model is "0" Can you help please!
  • herbroland Nov 14, 2008
    See original problem.
  • herbroland Nov 15, 2008
    Sorry, I do not need tech assistance. I know the problem and I only want to know how or where I obtain new gaskets. Please help without me spending £10.00. Herb Jones
I do not want to spend £'s to know where to obtain the replacement gaskets.
Posted on Nov 16, 2008
Why is there water dripping from my freezer door?
Can be a number of reasons
The door gasket is not sealing properly and needs to be renewed.
There is frost which is preventing the gasket from sealing.
Too much food which is preventing the door from closing properly.
Door Frame heater is not working.
and finally, Freezer switched off :>)
Sep 21, 2015 | Refrigerators
Door will not remain closed
Check to see if the shelves are not hitting the door shelves. the crisper drawers are in properly and there is not something too large in the door shelves. This is the usually reason for the doors not to stay closed. the other reason could be a bad door gasket.
Apr 21, 2015 | Refrigerators
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
My name is Peter. I am a retired field service refrigeration technician.
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
Gasker
On this model I will give you both gasket numbers as you didn't specify which one you needed. Freezer door part number 7010574, Refer Door 7010584. I verified that these numbers will match your serial number as you left it for me. I hope this helps you, good luck
Sep 16, 2014 | Sub-Zero Refrigerators
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
When I close the refrigerator door, the door will pop ajar unless I contine to push it for a second. The seal is in good condition. It feels like there is air pushing the door open. I have washed the...
raise the front legs and get some heavy stuff on the door shelves,also wah around the area where the gasket closes onto the frame,there are magnets in the gasket,also check to make sure nothing is hitting the door from the inside,when food is jammed in or the draw is sticking out to far and the door hits it it doesn't seal good and pops open.hope this helps
Feb 24, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag oven: How to clean
Before you self clean you always want to take a rag with warm water and remove all chunks of food.
Next clean around the frame of the door gasket with the rag(these cant get clean in self clean) do not clean gasket IMPORTANT
Remove all racks and pans
Most older door handle locks require a few buttons, get your model number(which is located either on the frame your bottom drawer shuts on if a single oven, if double is on door frame if built into cabinet walls, if on floor its on back of control panel, a piece of metal thats like a mailbox flag, you turn it to read model from front) and go to www.maytag.com click support then manuals enter your whole model number EXCEPT the last letter. (example if your model is MER6775AWW enter MER6775AW<--only one W) This should bring up use and care guide, which will give step by step instructions, if you follow them and it wont clean, your latch most likely needs replacement
May 02, 2008 | Kitchen Ranges
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
