Question about Honeywell Programmable Thermostat Heater
Honeywell ST6400C with no display
Hi, I just returned from holiday to find no display on my Honeywell ST6400C. When i went on holiday I turned the heating off but have done this before. Is this an issue with a fuse? The gas is working along with all the electrics in the house. I followed the instructions and pressed the reset button but nothing worked. Thanks
  • gmelville Nov 17, 2008
    Thanks for your help
  • Anonymous Jan 03, 2009
    yes we had the same problem over a holiday. The elctricity supply to the programmer was switched off. Bad idea! The solution proposed seems not appropriate. The st6400 is the programmer rather than the thermostat. The usual solution is to press the RESET button. But if this doesnt work how about replacing with the newer st9400? Circa £50-£65.. Same backplate and wiring.. (how about leaving connected to mains over holiday..?)
I pressed the reset button in error and the display just would not return o no heating or hot water. Nothing tripped on the board and all wires and the unit itself showed power coming through.I got it working again by sheer determination.
What I did
I took the unit from the base plate and opened the front panel to see circuit board. It has 4 clips and it all goes back together easily.
What I did.Time taken 15 minutes.
The tiny rubber reset button was collapsed, perhaps maintaining the 'off' situation.
I moved a tiny wire from touching the side of the battery.Perhaps not important but it didnt look right.
When i remounted the unit it lit up beautifully.
So the solution lies in 1 or all of these 3.
If it happens again I will try
1. simply remove the unit from its base plate and remount to see if that is all it takes.
2. Open the front and check the reset button isnt collapsed and stuck.
3. Just move that little wire from leaning against the battery -(least sure of why this might help)
hope this might help someone else
Catherine - a determined blonde lady
Posted on Mar 04, 2011
    Problem Solver:
  • 17 Answers
I am not familiar with this particular model but in general all digital thermostats are either powered by batteries or by the 24 volt transformer from the furnace. Usually the standard heat/cool type that you may have is powered by batteries and will show a low battery display for a few days before they go out entirely. You may have missed that warning because of your being away.
There will either be a small door on the front of the thermostat or you will need to pull the thermostat from the subbase and the batteries will be inside. Usually 2 AA size....replace with the good kind.
Good luck
Posted on Nov 14, 2008
Not sure that the advice above is appropriate. TheST6400 is a programmer rather than a thermostat.. we had exactly the same problem after a holiday exceeding the specified four day back up so the usual solution of pressing the RESET button didnt work. We are replacing ours with ST9400 honeywell computer that has the same backing plate and wiring. The answer seems to be, once installed do not switch off at the mains.
Posted on Jan 03, 2009
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
My st6400c Honeywell programmer blank. Mains turned of whole day. Now back on, but st6400c blank.
Have you tried pressing the 'Reset' button (with the tip of a pencil)? After doing this, you will have to re-enter the various times. It could be that your rechargeable battery is nearing the end of its useful life, by the way.
George
Feb 23, 2011 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C central heating programmer fault
you may vae to enter a different "Mode" to change the time....also try removing the batteries for 10 minutes and then reprogram the thermostat again
Oct 25, 2009 | Honeywell Electronic Programmable...
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
Display
hi it is most likely a faulty module
cheers grant
Sep 30, 2008 | Fisher Paykel EcoSmart GWL15
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
2,405 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
