Question about RCA P60928 TV
RCA P60928 I have a 60" that the picture all of a sudden viewed like you were watching 3D, then cut off.Lost power and could not turn on with remote, or by the front buttons of TV. unplugged to try to reset. Nothing, no power at all. Then took off front screen and speaker covers to clean red, green, blue lights. and con't to take apart back cover to remove all dust everywhere inside. Looked for fuse to replace. Found it and replaced it, now TV works, but still looks 3D and picture has curves at top and bottom. it is no longer squared. How do I adjust red, green, blue to view as one and not 3 separate colors. I tried to adjust lamps from behind TV by sliding nut left and right. If I get all 3 colors together, then picture is not focus or squared. Then I tried to adjust from front of TV the 3 screwdriver pieces for red, green, blue (focus and screen knobs), but still no luck. It's either all 3 colors together with blur or all 3 colors separate (looking 3D) with a clearer picture. Either way the screen still had an arch at the top like a smile and the bottom had an arch like a frown. Please help, it's a great TV had it for 7yrs first major problem!!!!
  • 308 Answers
SOURCE: bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Posted on Jan 01, 2007
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
SOURCE: RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Posted on Dec 25, 2007
SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Posted on Jan 05, 2008
MikeMaierTV
  • 206 Answers
SOURCE: RCA P61940 PROJECTION TV
No adjustment will fix this, what has happened is a power supply board for the convergance has failed and needs to be replaced or repaired
Posted on Mar 07, 2008
No picture showing after power on.
If this does not happen with other devices then I would say try a new video cable. HDMI cables can get very picky. If this happens at anytime then the inverter in TV is going out.
Sep 19, 2015 | Panasonic Viera Tc-p65vt30 3d 65 1080p...
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
While watching the TV the picture suddenly went out - still have sound. Turning the TV off and on again does not help - the POLAROID Logo displays, but when the station connects - still no picture
possibly external power supply faulty under load it may fail these power supplies ofen have capacitor failure open the power supply to check for leaking/bulging/swollen capacitor is around 2000uf rated at 12v
Apr 28, 2009 | Polaroid FLM-2011 Television
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W17 Picture is cut off at the top of screen
is it a black area on the screen? or just cant see the heads anymore? either way its proabaly a setting on the remote such as zoom or ratio
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
No sound or picture
What is your model number
Jan 08, 2008 | Televison & Video
RCA 32 in TV no picture no sound just a beeping noise TV power is on
You have a bad flyback transformer and shorted horizontal output transistor. Your set would have to be taken to a shop to have these parts replaced. Stargazer
Aug 04, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
146 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
