Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My washing machine
My LG washing machine keeps showing a error on it OE and im not sure what this means , could you please help find out what the code means ....
Thankyou
Mrs Groom
  • suzybabie72 Nov 14, 2008
    Thankyou for you help
  • 3 Answers
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Posted on Mar 25, 2009
  • 734 Answers
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
for further help go to --
LG
Posted on Nov 14, 2008
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Our lg washing machine has an OE error message what does this mean
Hi dear.OE code related to drain problem.Please checked the filter,open it,clean it & check for any obstacle blocking the pump to do it's function.(Impeller of pump should freely turn.)Please also check drain hose for kink & blockage.Please keep in mind,some times pump seems normal but it can malfuntion & needs to be replaced.If you are not sure,please call service centre.I hope that helps.Thanks.
Nov 12, 2010 | LG Washing Machines
Washer now shows OE on progess window after i tried to wash bathroom rug. Would not spin/drain excess water and door won't open.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine that has an OE error code.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | LG WM-2077C Front Load Washer
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
LG themselves have some information on this error code..
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG WM2277 "OE" ERROR. PLEASE HELP
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
Getting the OE error message on LG Tromm
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
My machine is showing an oe code and won't drain
Jul 03, 2009 | LG WM2496H Front Load
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
336 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
