Paper only feeding in at one corner -Epson DX5000
  • 1,447 Answers
Check for any obstruction, if there is none try running a single sheet of paper by pressing the copy button. if all fails, the sensor and mechanism for grabbing paper is already damaged.
Hope this helps
Posted on Nov 14, 2008
Hi I have a Stylus Epson DX5000
Online Best Epson printer support by toll free phone number 1-800-204-4427 to fix troubleshooting issues. We provide Epson printer technical customer service ...
Apr 13, 2017 | Epson Computers & Internet
Epson dx5000 scan driver
go to following link you will find your drivers
Oct 26, 2010 | Computers & Internet
EPSON DX5000 will not feed paper. It goes in about 1 inch then stops. No jam warning until it appears to finish printing. When I renmove the paper there appears to be a small dent in the leading edge of...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Epson Stylus DX5050 All-In-One InkJet...
Hi the paper feed pulls the paper into the printer with a snatch type action and on one side of the paper causing it to jam ? the printer is a epson DX5000/CX4900 series.
***hi there,il be willing to help you on that. ****
there is a great possibility that the rollers of the printer is having an issue. but try there steps first , do a self test on the printer, run a blank sheet of paper, if it jammed, that means the printer itself is broken
put plain paper in the sheet feeder, then press the start button. if it jammed, remove the paper jam and try again.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Office Equipment & Supplies
Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Need instructions for epson stylus dx5050
Here is guide for CX5000, that is same model as DX5000
User's Guide
Below you also find assembly instructions:
EPSON STYLUS CX5000 / DX5000 / DX5050
Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Can't open Epson DX5000 to remove object stuck inside
sounds a little draconian, but sometimes if you invert th peinter and give it a tap, the foreign object may fall out. Just don't leave it upside down too long!
Dec 15, 2008 | Epson Stylus Multifunction Inkjet Printer/...
If it is not pushing the paper out of the tray, you should first try taking a soapy cleaner like fantastic or formula 109 and clean the feed rollers and see if that helps.
The paper tray also lifts up and down to feed the paper so the gear that drives the tray up and down may be broken.
Slen the rolls first. If that doesn;t last long. Say in a day or two it starts misfeeding again, the rollers will need to be replaced.
Mar 23, 2008 | Office Equipment & Supplies
231 people viewed this question
