Question about iRiver Audio Players & Recorders
I have an iriver h100 wit h40gb harddrive which operates with a simple drag and drop system with windows. Currently it won't allow transfer of files from a pc to the player, it begins to transfer and then nothing happens. The player works fine apart from the fact that I can't transfer anything onto it. I have formatted the drive through windows and the player itself, there were no problems doing this but it didn't solve the transfer issue, I have also scanned the disk for errors using windows and it returned no errors, can you help?
  • 4 more comments
  • Ganesh81 Nov 14, 2008
    Hi
    The file transfer box pops up, the transfer begins, it will transfer one or two songs and then the bar on the file transfer box just freezes.
    There is no lock and the hold switch is definitely off. It usually transfers one or two songs then stops.
    I have an iriver h100 with a 40gb harddrive which operates with a simple drag and drop system with windows. Currently it won't allow transfer of files from a pc to the player, it begins to transfer and then nothing happens. The file transfer box pops up, the transfer begins, it will transfer one or two songs and then the bar on the file transfer box just freezes.
    help?
    Hi, I tried it on my pc and laptop, the problem persists, one uses xp and the other vista. The battery is fully charged and fine, however I was using the AC cord when trying transferring & formatting.
    Same problem after formatting and resetting!
  • Ganesh81 Nov 17, 2008
    Have tried all the usb ports on the system, it cannot be the cable as I use different cables with the laptop and the same problem occurs
    Genius:
  • 1,913 Answers
First go to my computer then tools then folder option then enable show hidden files and folders.
also show system files.
then go to copy data then select only what u want to copy then simply paste.
Posted on Nov 14, 2008
    Sergeant:
    Champion:
  • 331 Answers
I am guessing that the USB cord might be at fault here
did you try connecting the Media player using a different
USB cord?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to replced the usb cable
or use another usb port of your computer?
  • 734 Answers
1. Take a try, uninstall the driver you are using for iriver h100 and again install it. 2. Check that you’re USB (on computer side) or iriver connecting port getting proper connection NO Lousing of wire
Thank you for using FixYa.
  • futureloginn
    futureloginn Nov 14, 2008
    check the blow site for full help on.. .. ,
    SITE
  • futureloginn
    please try the link i'll give
    Brigadier General:
  • 6,966 Answers
A couple of ideas you can initially try/explore:
  • try the iRiver H100 with another USB port of your PC, or in another PC and note if problem persists;
  • disable the Power Management of the PC's USB port;
  • enable Legacy/DOS USB feature of your PC in the CMOS/BIOS.
Additionally, have you considered a firmware update (if ever available)?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Master:
  • 763 Answers
After formating and still your problem persist then try it to another computer which operates windows xp too and see if it works aside from your computer. if that thing has a reset button then reset it after formating. give that also a full charge cause sometimes low battery will give disfunction on formatting.
thank you for using fixya
CHARCOIS
  • iRiver Master
  • 19,396 Answers
Check that the player is not locked from writing.
There must be a small tab on the player side.
  • Ginko
    Ginko Nov 14, 2008
    If you are using a usb cable (eg extension or usb hub) remove the hub, or replace the cable, just in case.
    transfer one or two songs and then freezes, that means that there are bad sector in the solid state disk (the flash memory).
    If you already formatted (complete format, not fast one) the disk and it did not work, then the unit is faulty.
    Try doing a complete format from windows, then possibly test the MP3 on a different computer, if it does not work, the flash memory (disk ) is faulty.
    If the MP3 is less than one year old you can get a replacement, if it is over one year old, you can probably buy a warranty extension for a small fee, call Iriverusing the phone number listed on the manual, or find contact on website : Iriver
  • iRiver Master
  • 13,433 Answers
What happens when you try to move a file into the drive?
  • Ekse Nov 14, 2008
    That does sound like a faulty drive, plug the player into your computer, open my computer and find what the drive letter of the drive is. for example E:
    now press start -> then run -> type in Cmd
    If the drive letter is E:
    in the shell window, type in CHKDSK /X /F /R E:
    it will scan the whole drive, report back with results.
I need the software from the CD. I loast my CD and i have anew PC. I want to remove the audio files on my iriver IFP-795
Please download the iRiver Music Manager from the following link.( http://local.iriver.com/usa/lounge/loungeView.asp?selectPart=cateCode&findWord=01&sno=859&page=1&cateCode=01 ).The detailed instructions to transfer audio files between your player and computer is explained below.
1.After installation of iRiver Music Manager, please drag the file as follows
2. After dragging file you can see the below window
3. If you want to make another folder in your device,please take a look at the image below
Please don't forget to rate me if satisfied.........
Jun 04, 2011 | iRiver iFP-795 MP3 Player
Tip
Apple Compatability
iriver:
Hello! This is iriver supporter. Please enter your question, then simply click 'Go' button or press Enter key.
Maxicube:
[H10 H100 H300] apple software
iriver:
Are you asking me that "(Harddisk Player)You want Macintosh compatibility information"?
Maxicube:
Yes.
iriver:
H10 & E10 Players
H10 Players are only compatible with Windows XP. They cannot be used on Windows 98SE / Me / 2000 or Macintosh computers.
H100 Series, H300 Series and iGP players
The H100 Series, H300 Series and iGP players are compatible with Mac OS versions 9.2.2 and 10.2 or higher. When attached, the player will display as an icon on the desktop. Open the icon to add files to the player. Note, the DB functions described in the manual are not available for Mac OS at this time, as the index cannot be created with Mac OS. This means that Album, Artist, Genre, and Title searching will not be available.
For The Iriver Bot Goto http://www.iriveramerica.com/support/contact.aspx
on Feb 10, 2008 | iRiver E10 Digital Media Player
Iriver won't let me upload from CDs and transfer....
go to my computer and open the C drive /create a new folder my music (rename it) ...ok now plug up iriver to pc...again go to start/my computer/ see the iriver drive open it...now you should see all the files on the iriver also...place both window side by side (or top & bottom) and click & drag (or copy & paste) from both iriver and pc...now you can save and copy from either one..........
May 30, 2009 | iRiver H10 MP3 Player
IFP-790T
I found an updated firmware file (Don't know where I got it) and once it was installed I could see and transfer music files from Windows Media Player 11 to my iriver ifp 790. You can email me at saslats@roadrunner.com if you would like me to send you the file.
Oct 30, 2008 | iRiver iFP-790 MP3 Player
Downloading videos onto the iriver E100
Software / Media Transfer The E100 comes packaged with a disc containing iriver plus 3 media player, firmware updater, video converter, and Windows Media Player 11. If you have owned an iriver player, you are familiar with this software with the included iriver media player. This is a standard media player much like any other but has a few features catering to the iriver family of players, such as a firmware updater, ebook txt manager, and video converter. This media player is a bit different from Windows Media Player but still is straightforward and easy to use. If you don’t care for iriver’s media player you can always use any other MTP based media player to manage playlists and load your E100 since also included on the disc is a video converter and firmware updating utility.
If you don’t like to use media players to transfer the E100 will allow you to select either MTP or MSC transfer mode. This means it is drag and drop and also compatible with any OS. Drag and drop will work fine in MTP mode as well, but only if you are using Windows XP SP2 or Vista.
and the difference between e10 / e100 your guess is just as good as mine
Sep 22, 2008 | iRiver E10 Digital Media Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
Transfer files from disk to iriver ifp-895
The songs are probably in the wrong format. convert them all to Mp3 format, and try again.
Aug 26, 2008 | iRiver iFP-895 MP3 Player
Device driver for iRiver IFP-899 on Vista
I can´t connect to my PC with my iRiver device (iFP-890) and Wi Vista 64 with SP1, not trough Music Manager or Explorer.
I´v followed the instructions above.
Mar 13, 2008 | iRiver iFP-899 MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
I need a program
You don't actually need a program to access the iriver on your computer as long as there is a fresh battery in it, a USB connection, and using windows explorer. Iriver has the capabilities to drag and drop files into it. Just goto "my computer" (on your desktop) and look for "removable device", which will be your MP3 player.
Apr 04, 2007 | iRiver iFP-795 MP3 Player
64 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
