Question about Panasonic PT-52LCX66 Projection Television
Split screen When I switch from Hi Def Channels to Digital channels on my Panasonic PT-52LCX66 I get a split screen which has a greenish tinge. I thought it might have been my cable box but it wasnt. If I turn the tv off then on again it fixes the problem until I go back to Hi Def and switch back to digital channel. Thank you
  • j2dmaxx Dec 26, 2008
    I have the same problem and thought it was the cable box as well. The cable person could not replicate the problem (nor could I). I power off the tv and turn it back on as well.
    Additionally, my picture appears to be darker than normal even when it is set to "vivid".
  • 2,335 Answers
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Posted on Apr 15, 2010
I cannot turn to channel 3 anymore to receive cable service.
Do you have a Hi Def box? If so, connect component cables from the box to a input on TV. Also try to change channels manually on set.
Nov 11, 2013 | Panasonic PT-47WX49 47" Rear Projection...
Tip
Panasonic PT-52LCX66 Manual Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Have you lost the Operating Instructions for your Panasonic PT-52LCX66 Projection HDTV?
Click here to download a digital, searchable copy of your users manual / owners guide.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-52LCX66 Projection Television
The lamp hour meter needs to be reset for Panasonic PT-52LCX66 Television. How do i reset it?
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-52LCX66 Projection Television
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Oct 10, 2009 | Panasonic PT-52LCX66 Projection Television
Need to reset the lamp time on my PT-52LCX66
To reset lamp timer in Panasonic PT-52LCX66..
Press and hold Volume Down button on TV front and press and hold 0 (zero) button on TV remote at same time for 6 seconds, a lamp reset message will appear on TV screen.
Thanks.
Sep 02, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT-52LCX66 Television lamp reset time
With tv 0n press vol- (minus) on tv and hold. then hold 0 on remote hold both for about 5 sec.
Feb 22, 2009 | Panasonic PT-52LCX66 Projection Television
Split screen
use a vcr with a tuner or modulator so that you have two tuners for the separate channels. The tv has one tuner and Pic in Pic requires two tuners or sources.
Dec 08, 2008 | Panasonic PT-43LC14 Television
Blue ghost on left side of screen only when on hi def channels
hello its sound like you need to replace the (IC chip) for your blue (CTR gun) .!!! its going bad.!!!hope this help's you ."good luck"
Jul 19, 2008 | GE 46GW947 46" Rear Projection Television
Panasonic PT-52LCX66 Projection Television Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
