Question about Sony Cyber-Shot DSC-P73 Digital Camera
Flash and Shutter not in synch
The Flash does not consistently go off and when it does, most of the time is either provides a washed out photo or a dark photo even while taking 10 pics in a row in the same setting on the same setting. What is the deal with this inconsistency? I am allowing time for the flash to recharge and it does show a ready indicator before I take the next photo.
    Problem Solver:
  • 36 Answers
Good Day, flash assy is defective, the light sensor that will detect the correct flash exposure is defective, no longer user serviceable, contact nearest svc ctr for replacement of flash assy. thanks
Posted on Sep 03, 2007
Hello, Please help me I love my camera! The last 3 rolls of film I have taken only the last half of the roll come out the first part of the film is black I'm only getting half of the pictures I take. It's...
Most likely this is a shutter problem. If you are using flash and getting the half pictures, then make sure the flash is a canon compatible flash and the synch is set to 60th. If the problem is all the time including non-flash pictures, then the shutter will have to be repaired.
Mar 26, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Feb 17, 2010 | Sony Cybershot DSC-H3 Digital Camera
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Photos washed out or completly dark
Sorry to say this sounds like a stuck shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
May 10, 2009 | Canon PowerShot SD1000 Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Flash doesn't synch with shutter on olympus e-420
Well a good photographer dosen't  use a auto to much.  Second you can solve  this problem by  buying a 36r or 50 r  flash.  Next put your camera into aperture priorty the flash will now sync up to 4000. I hope this solves your problem..  lesmobile1@yahoo.com    www.storyboardvideo.com
Feb 28, 2009 | Olympus EVOLT E-500 Digital Camera
Black bar on rt. side of photos.
elockepens
is this black bar on all the time or only when using flash? if only when using flash then your shutter speed is to high. for flash on the K1000 the shutter speed must be 1/60th sec. or slower.
if the black bar is there all the time then the shutter must be adjusted, cleaned and lubed.take or send your K1000 to a camera repair shop for an estimate first as there are no new part available,
Feb 02, 2009 | Pentax K1000 35mm SLR Camera
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
Dec 03, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Flash and high shutter speed problem
Actually you cannot take 'High Speed' photos and flash they way you are thinking- Even even with high spec pro cameras - it does not work that way. The Flash speed is in the order of 10,000th sec. So all the shutter has to do is open for a long exposure - because synching the the flash is hit or miss And it is the Flash that does the exposure.
Aug 29, 2007 | Nikon D40x Digital Camera
Panasonic TZ1 flash problems!!
Panasonic knows about this and can fix it. It involves replacing a circuit board. I sent them my camera (Elk Grove Village, IL repair facility) at the beginning of Dec with a letter giving six web sites reporting the problem and asking them to fix it free of charge. I don't think the camera was on warranty, but I received it back, fixed, and with no charge, in about a week. Panasonic really came through on this and there is clearly no fix other than this one... except to stop trying to take flash pictures.
Jul 30, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
