Question about Car Audio & Video
Playing Ipod through a CDr 500 unit in an Astra
I want to be able to play my Ipod through my car stereo but as I live in London the Itrip systems don't work. Any suggestions much appreciated?
5 Suggested Answers
  • 3 Answers
SOURCE: Hooking up an Ipod to my stereo
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
Posted on Apr 05, 2008
SOURCE: can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Posted on Sep 25, 2008
elecgooroo
  • 57 Answers
SOURCE: Cannot Manually Tune The Radio CLARION DRB4475R CAR CD PLAYER
check your setting on the itrip unit to make sure it is set for frequency
Posted on Jan 10, 2009
SOURCE: GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Posted on Jan 18, 2009
  • 265 Answers
SOURCE: Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
Posted on Apr 06, 2009
PLAYING IPOD THRU SYSTEM
i think you will have to try a new adapter for getting this problem fixed.
please use a new one
Sep 29, 2008 | Pioneer DEH-P4600 CD Player
Kenwood kdc mp 232 how do I get to the aux when
turn the ipod off why would you want it on not listening to it anymore?
Jan 15, 2010 | Kenwood KDC-MP232 CD Player
I was playing a song off my iPod using the line-in mode on my KD-LH3100 head unit and the unit suddenly turned off and I have not been able to turn it back on! I am running an amp and 2 subwoofers in...
Did you check the fuse behind your stereo. IF you did and it still wont come on you either lost power to it or it may be time to have your unit repaired or replaced. You should have inline fuses behind the stereo use a test light to check that there is power coming to your fuse
Sep 19, 2009 | JVC KD-LH3100 CD Player
My car stereo shuts off while driving and playing
if you have had the head unit for long, it might be over heating and going into safe mode so it doesn't get to hot. This happened to my amp and i never did anything until it stopped working all together. so my guess would be just to get another head unit or get some type of cooling system.
Sep 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Jan 07, 2009 | Clarion DB538RMP CD Player
Re Coding my Siemens CDR 500
Hi, Try this:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Hope it helps.
AlterEgo
Apr 18, 2008 | Car Audio & Video
HELP PLEASE
Probably, but don't buy this stereo! It has a lifespan of about 6 months. I am not the only person to have had the same series of events happen with my VR-3 stereo. The same breakdowns I had, were mentioned by other customers on www.vr-3.com. The usb, and SD slots will breakdown. I have played my MP3 player throught the Auxiliary port, (which would be the way you play youe ipod) but the sound quality is not great. It requires that you turn the mp3 unit up to full, and increase the volume on the car stereo significantly, and still not great sound. I am actually planning to contact Target where I purchased mine, and reccomend they drop the product.
Dec 21, 2007 | Virtual Reality VRCD500-SDU CD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
Alpine Ipod/Stereo Error 1 message
my alpine cda 9856 only displays that message when my ipod dies. so your ipod pobably dies then the head unit recharges it enough in the time your resetting it that it can play again. :)
Nov 26, 2006 | Alpine CDA-9857 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
