The lamp only affects brightness. If the color is not correct the lamp will not fix this. Check cables if using the color stream input. If color is off on all inputs and even the tv menu then replace the light engine. If you could list the brand and model I could give you some more helpful information.
Well you could replace the lamp that would be a cheaper approach then buy a new TV. Now these lamps should run over 4,000 hours but I could be wrong its all on the manufactures spec's.
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
