Question about Fujitronic FH747RI Halogen Compact Heater
Non working haogen wall heater
Bulb keeps blowing and currently non operational, any ideas
  • 833 Answers
First, you'll need to check all connections going to the unit.  Often, a poor connection will blow bulbs and not allow enough current to pass for heating.  Also, check any switch external to the unit.  Use a good meter to check for resistance.  It should be nearly nil.  Be sure to do all checks with the breaker off!
Posted on Nov 15, 2008
Hot tub keeps blowing fuses. Only happens when the heater is on, any ideas?
According to the description, it looks like too weak fuses, respectively too strong current when heater is on. Heaters generally consume high currents, and when motor and heater run together, the current (amperes) may be too strong for the fuses.
May 17, 2015 | Pool & Spa
Y does my glw-warm heater keep shutting off
Is this an unvented heater? They have oxygen depletion sensors which shut off the heater to prevent burning up all the oxygen in the room. Heaters over 10,000 btu's should not be used in small rooms like bedrooms and bathrooms. Other causes could be a dirty pilot orifice. Turn off the unit (so pilot is off) and use a can of compressed air with attached straw, to blow out any dust from the pilot assembly. (Where the pilot flame comes out). This will allow the pilot to burn a strong blue color and keep the thermocouple heated properly. If it's a thermostatically controlled heater, make sure your thermostat bulb is cleaned off regularly. Dust will insulate the bulb from sensing the room temp and will not operate properly. Hope this helps.
Mar 25, 2015 | Heating & Cooling
Heat not working in 1998 mazda milleni S
OK if heat no blowing out just cool air #1 check your engine coolant level add if needed to res bottle and radiator, (wait until engine is cool to the touch before opening the radiator cap under pressure when hot!)#2 if good on coolant and your engine is getting to normal opperating temp as always you may have a clogged heater core, if so you can test the heater core flow by removing the to heater hoses mounted at fire wall in your engine compartment and with a garden hose at low volume push water through one of the two copper hoses coming out of your fire wall if the entering amount of water is coming out the other copper pipe then your heater core is good.#3 then if all the above is good and working your dealing with a blend door not operating properly inside your heater box located under your dash (not for the non experience to repair)
Jan 10, 2012 | Mazda Millenia Cars & Trucks
Boiler keeps blowing fuses in pcb ideal isar he 30
The model # you listed is for a vent-free, natural gas, space heater and requires no electricity to operate. Unless, you have the optional blower. If the blower accessory is what's blowing the fuses, there is a short in wiring to the blower motor. Other than that, there is nothing else about this heater, that would be blowing fuses.
Is the above, the problem you're having? If so, unplug the blower from the wall outlet, until it can be repaired or replaced. The heater will continue to operate and heat with out the blower.
For more information about your heater, go to the link below.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107882-01.pdf
Mar 04, 2011 | Desa International CBN30T Central Heating...
Why does the right headlight bulb in my 1993 ford escort keep blowing out. Usually takes about 10 min for it to blow.
You should try replacing the socket with a wiring pigtail kit using dual wall heat shrink tubing. High resistance due to a poor connection can cause current to e too high. The only other eason would be water leaking on the bulb or into the connector.
Jan 26, 2011 | 1993 Ford Escort 4 Door
Hi, small sidelight fron driver side keeps blowing/stops working (cayenne s 2004) any ideas?? Also limited slip lever no lights/function (non PASM car) any ideas - fuse?? Thanks
side light take it out and check the bulb connections ,bend contacts up a bit drop of engine oil and that should cure the light ,now as for the other thing i havent a clue ,if i car car in front of me i could sort it out but from spain ??
Oct 27, 2010 | 2006 Porsche Cayenne
Air is blowing out the pilot, gas wall heater
Look in your yellow pages and call in a GAS FITTER to look at the unit.
Dec 12, 2009 | Honeywell Heating & Cooling
1984 ford ranger keeps blowing the running light fuses. when i let it sit at idle it won't blow the fuses but as soon as i start driving with in 5 mins or so it blows.... any ideas?
short in the wires will need a wiring diagram and ohm/volt meter to locate the problem, test lights work well to.
you will need replace the fuse with a light bulb so that the power will not go away. and you will have to search for power going straight to a ground source.
usually a raw wire from rubbing somewhere. can do a quick visual inspection first for the obvious, and then use the meter at certain points till you find a volt drop.
May 13, 2009 | 1984 Ford Ranger
New heater pilot will not stay lit
gas and fire, I would return it before you blow something up.
Oct 03, 2017 | Ace Hardware ML250TPA Infra-Red Wall...
Fujitronic FH747RI Halogen Compact Heater Logo
46 people viewed this question
Top Fujitronic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
