Question about Garmin StreetPilot c550 GPS Receiver
How do i reset the c550
The directions for resetting the garmin c550
  • 435 Answers
To perform a master reset on the StreetPilot c5xx series:
1. Power the StreetPilot off (ensure that it is not connected to external power)
2. Touch-and-hold your finger in the lower right corner of the Touchscreen
3. Power the StreetPilot on
4. Continue to hold your finger there until "Erase all user date?" appears
5. Remover finger from the Touchscreen
6. Touch "Yes"
Please rate the solution....
Thank you
Posted on Nov 14, 2008
Forgotten my pin number for garmin and my secret location. how can i access/reset it please?
Welcome to FixYa!
Here's how to reset Garmin Street Pilot C550:
1. Remove the front plate of the c550 by sliding your finger under the groove in the plate below the Garmin mark on the plate.
2. Push the now-exposed reset button. The reset button is located on the same side of the c550 as the power cable connector.
3. Plug the c550 into an external power source to restart the c550 after you have reset it. The factory default settings will be restored.
Thank you for using FixYa.
Have a great day.
Jas247
Apr 26, 2011 | Garmin StreetPilot c550 GPS Receiver
Hello i have a garmin c550 gps and for some reason it blocked on me i forgot my pin nunber i guess... i dont know how to reset it and i dont have my manual with me....
The manual would not help you. Resetting the unit (even a Master Reset) will NOT remove or reset the PIN. Your options for unlocking a PIN locked Garmin are:
1 - Enter the correct PIN.
2 - Take the unit to the location at which the PIN was set.
3 - Return the unit to Garmin.
Nov 20, 2009 | Garmin StreetPilot c550 GPS Receiver
Code problem
to reset the c550 place your thumbnail in the groove located under the garmin logo on the faceplate. Gently pull off the faceplate and press the reset button then connect to a power source and the unit should automaticly turn back on.
Dec 21, 2008 | Garmin zumo 550 GPS Receiver
Is there a way to reset a garmin c550
http://www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf page 29 & page 30 discuss the 2 options for reset/restore.. one clears all saved data (i.e. favorites) & the other resets the system. I'd also suggest connecting the usb cord to ur pc & GPS , then use the update software, This can resolve any issues you may be experiencing.
Dec 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Forgot pin number
The only way to unlock a PIN locked Garmin is to enter the correct PIN number, or take the unit to the location at which the PIN was entered. Your only other option is to send the unit to Garmin.
Jul 16, 2008 | Garmin StreetPilot c550 GPS Receiver
GARMIN C550
hey u got to try 4 digit.. try to do it the most you cant and belive me u will unlock your garmin c550...after felling alot of times will go back to reset and it will unlock..good luck
Feb 26, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin C550
Remove the front faceplate, (there is an indentation under the word Garmin on the faceplate that you can use to lift it with your finger nail). After removing the faceplate you will see a reset button on the right side. Press the reset and then try to turn the Garmin on.
Jan 30, 2008 | Garmin StreetPilot c550 GPS Receiver
Screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Oct 05, 2007 | Garmin StreetPilot c550 GPS Receiver
Pin unloock
how do i unlock my garmin i never put i pin number but is asking me the pin is a garmin street pilot c 550 thank you
Sep 23, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
366 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
