Question about JVC DLA-RS1U Projector
JVC DLA-RS1U Projector turns off
Projector turns off after about 10 minutes
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Posted on Jul 01, 2012
SOURCE: Playing blue ray movies on jvc dla sx21 projector
Did any suggestions work? I have the same projector and am thinking of
upgrading to bluray dvd player. When i tried before, I had HDCP issues. Thanks.
Posted on Mar 20, 2009
  • 2237 Answers
SOURCE: Blinking Stand-by and Operate
the lamp needs replacing.
Posted on Aug 19, 2009
  • 1871 Answers
SOURCE: Excuse me I recently changed the bulb on my JVC
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
micro fiber duster
avoid touching the bare projector lamp
I hope this will help .
please rate !
Posted on Apr 12, 2010
  • 1216 Answers
SOURCE: After JVC G15 runs for
the bulb of your projector have a lamp life of 1000 hours and this is probably the decline period of your bulb, that is it's life is near it's end.
Emergency light signifies this only and this is the cause of your problem.
please replace your bulb.
Posted on Dec 12, 2010
  • 629 Answers
SOURCE: I have changed the lamp but can't reset the lamp
try turning off the projector, disconnect the power cord and remove the lamp again. then press the power button for about 10 seconds to fully drain power. afterwards, connect/insert the lamp again making sure it is securely connected with the cover, power on the device and attempt to reset the lamp time again. let us know how it goes.
Posted on Dec 26, 2010
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
Nov 02, 2013 | JVC Dla X3 3d Projector
Washed out colour
Check the bulb for signs of discoloration or dark spots. Seems like the bulb is failing.
Jan 28, 2013 | JVC DLA-RS1U Projector
When i put my DLA-D15 on the standby ligth goes on when i put operate on it come and goes off after 10 seconds and the fans don't operate.could you tell me whats wrong?and the lamp has only 200 hours
First of check the lamp of your projector. possibility of lamp burning. Remove the lamp from the projector and check whether it burned or not. If not, insert the lamp back and close the lamp cover properly. If the lamp cover is not properly closed this problem can occur, because there is switch to sense whether the lamp cover is closed or not.
If these will not help then you have to open your projector. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Mar 08, 2011 | JVC DLA-G15U Multimedia Projector
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
Surround sound and TV sound
Not by just pressing a button the Home Theatre no , I have the same problem on my Panasonic system - and I just mute the TV.
Mar 28, 2008 | JVC GL-M2915SG, Short Focus Manual Shift...
How to operate jvc surround sound,no book
I have a jvc s5975, and cannot remember how to sort the clock.
anyone got any ideas?
Nov 20, 2007 | JVC GL-M2915SG, Short Focus Manual Shift...
JVC DLA-RS1U Projector Logo
683 people viewed this question
Top JVC Office Equipment & Supplies Experts
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
