My zanussi 1050 does not stop spinning - Washing Machines
    Scholar:
  • 131 Answers
Hi there aih 1,if in fact you mean the spin cycle does'nt quit when you lift the lid,STOP RIGHT THERE(THIS CAN CAUSE GREAT PERONAL INJURY) if on the other hand you mean it gets to the spin cycle & remains there,it could be anything from the timer,to a relay.in any event without more detailed imfo this all i can tell you.unless you are familiar with working on things of this nature i would suggest you call in a service proffesinal.hope this helps.thanx for using fix-ya & please rate all replys
Posted on Nov 15, 2008
Hi, my zanussi nexus fl884 wont spin, I cleaned the fluff filter but still wont spin
I would check the brushes on the motor. If these are worn that can stop the machine working full spin under load
Jan 11, 2018 | Zanussi Washing Machines
My Zanussi FJD1666w spin cycle isn't working. Any ideas?
Machine spins but stops.. loading imbalance.. try with less load.. or drain pump and valve not working.. check for block..
Jan 26, 2015 | Zanussi FJD1666W Front Load Washer
My zanussi zwf1221w won't stop spinning. Any ideas
Check for a blocked filter. Or it could be your pump thats failed.
Mar 30, 2012 | Zanussi Washing Machines
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
