Question about Maytag Atlantis MAV6451 Top Load Washer
Timer stops at rinse cycle
The timer stops at each rinse cycle. By slightly turning the timer wheel the cycle resumes and finishes until next time.
Replace the timer
Posted on Aug 08, 2007
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Never finishing the cycle
you need a new timer.  it's an easy replacement.
Apr 04, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher will not finish cycle
Oct 19, 2008 | Dishwashers
Still confused ...
the timer should be moving by itself to rinse and spin and than finish the cycle
If your timer stop at rinse cycle you gonna need a lid switch.
Problaby your lid switch is broken
May 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Mar 29, 2008 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
