Question about Dell E176FP 17" LCD Monitor
No Power, No lights ... Nothing! Is there a fuse inside?
Tried new leads, but button does not light up on monitor, no sign of life?
Any ideas please?
    Brigadier General:
  • 6,966 Answers
Definitely an internal power supply issue. Dell uses a combo inverter/PSU board with P/N 790441202. This particular board uses a tablet type fuse very near the AC jack. Should a replacment be warranted rather than component level repair, pls reference this page.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 14, 2008
Technika
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Televison & Video
Benq FP737s - Not working suddenly - Black screen
Most like just burned out and needs repaired or replaced.
Nov 11, 2007 | BenQ FP737S-D 17" LCD Monitor
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Need help! My Samsung 2232bw monitor wont start the screen! On/Off button light, turns on and off all the time, but no picture! I've tried, to unplug and plug in the DVI, but nothing. It even wont show...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
Mar 27, 2011 | Computers & Internet
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Don't know how to turn it on
Check power lead,press the button on the right at the bottom of the screen if a light comes on then it is on. Start PC, light should go green and monitor should give a display. If there is no life at all then the monitor is dead, change it :( If the light is on but starting PC doesn't give a display then check lead from PC, try another monitor with PC and if it works change resolution to something basic like 1026 x 768 @ 60Hz then try the acer again. If another monitor doesn't work your PC has a graphics problem; Check the lead thoroughly, check in bios settings the display is set right, try a new graphics card
Aug 02, 2009 | Acer AL1916W 19" LCD Monitor
Green Power light blinking
Check the resolution in the Windows while connected to the old monitor. If greater than 1280 X 1024 and/or the refresh rate exceeds 75 Hz, the monitor may not respond. But you should at least see the BIOS splash when the computer is turned on. If that does not appear, maybe a problem has occurred in the monitor. Another indicator: if you turn the monitor power button off and then back on, you should get some sign of life such as "no signal", or "out of range". If nothing appears, that would indicate some problem within the monitor.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 04, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
Ipod touch 8gb
I ran an apple USB lead from my Mac Book to my iPod touch with i Tunes running and that did the trick.
Sep 17, 2008 | Apple iPod touch
Asus NRL-LS P4 MB power on issue
unplug the power wait for 30 secs, then plug in and retry
Dec 27, 2006 | HP (311185-001) Motherboard
Dell E176FP 17" LCD Monitor Logo
220 people viewed this question
Alun Cox
