Question about HP LaserJet 1005w Printer
Hp1005 Saying there is a paper jam. I have replaced paper turned on and off and still no luck.
  • 2 more comments
  • dadaxon8509 Dec 18, 2008
    I NEED DRIVER HP 1005. I LOST MY DESK OF HP 1005
  • Anonymous Feb 26, 2009
    I have a similar problem- whenever the paper runs out, the print jobs still pending get stuck in the queue and I have to reboot to remove them, even if I have replaced the paper.
  • Anonymous Mar 17, 2014
    how to remove jammed paper from hp1005
Why HP company is so stupid?
Why can you not let the customer easily to download the driver? Why?
Posted on Mar 18, 2009
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
It is saying paper jam but there is no paper
one of the paper feed sensors are jammed closed / i would give it a robust kick with any luck it will free it up if not your best of replacing it
May 15, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
HP1005 says out of paper but there is plenty. One
In run window type services.msc and the go to print spooler option just stop and restart the service.and switch off and switch on the printer it will clear the queue.
Oct 21, 2009 | HP LaserJet 1005w Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
Paper jam, need help urgently!
First check the Paper feed roller they maybe slick from paper dust, you need to clean them, then turn of the printer and remove the ink cartridges, turn macine over and check the under side of the machine for any sign of paper, remove any seen, then turn back over reinsert cartridges , turn machine on. paper dust sometimes covers the paper read sensor , causing a paper jam, and slick feed roller also contribute to frequent and pervasive paper jams.
Jul 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Hp printer keeps saying "resume".
Do a complete reset.
1- Clear the printer queue.
2- Turn off the device.
3- Remove paper in the tray and possible paper jammed.
4- Remove ink toner.
5- Turn on the device briefly and turn it off.
6- Replace paper and toner.
7- Turn on!
Mar 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
My Canon ir c2100 has a paper jam issue.
Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly.. Good Luck...
May 22, 2008 | Office Equipment & Supplies
HP LaserJet 1005w Printer Logo
650 people viewed this question
Seeker5211
Seeker5211
