Question about Samsung RS2578BB Side by Side Refrigerator
Samsung rs2555sl The fridge has stopped cooling - power is getting to it and the freezer part is still working.
Hi, Samsung rs2555sl Side by Side Refrigerator the fridge(fresh food) the problems frozen up the evaporator i did unpluged the fridge 2 days and the same problem still getting warm so it could the fan not working or the tempurature or some thing els please let me know thank you Regards, tin huynh
  • harshita Jan 15, 2008
    Hi I have the same problem, I bought my fridge just few months back from Bond & Bond, St Lukes, Auckland. The fridge was not cooling and the frezer was making more ice. Repair man came and said the defrost element not working. He said the fridge was given on a discounted price as it was faulty.
    I feel completely ripped off. They purposely sold this fridge to me and are not ready to replace although it is still in the guarantee period. Have had a lot of milk and food stuff spoilt and wasted and it has been hard with two children and a fridge that doesn't work properly and spoils milk and food in 24 hours.
  • mikey19802 Jun 12, 2008
    fan not workin
    g
    Problem Solver:
  • 7 Answers
Check the line temp(fuse) and replace sensor
Posted on Feb 22, 2007
  • 237 Answers
You say the evaporator is freezing up? If the defrost timer, defrost heat element or defrost t-stat isn't working then you will not have a defrost cycle. That can cause a freeze up. As for the warm side frige, that could be the fan isn't circulating the cold air to the frige section, the air dampers are not working properly, the air channels themselves are frozen shut so you won't have air "circulation" flow. Can you feel cold air being blown into the frige area with the freezer door closed? If you open the freezer door does the air flow now? Also can remove the back panel cover in the freezer section and look at the evap. coils to see if there is a full even frost pattern on all the coils (is good) or if there is a sudden stop to the frost pattern and bare coils showing (is bad).
Posted on Nov 19, 2006
Hi my name is joe ,
those fridges they do not have dampers they have dual evaporator coils and the problem its just unplug and plug all the wiring plugs by the evaporator coil from fresh food they are starting to oxidize
Posted on Oct 22, 2007
Mine exact same model has the same problem. It is caused by a small leak that can't be repaired by the Best buy repair man. The refrigerant slowly releases over time and the compressor works harder and harder and then finally either the refrigerant is gone or the compressor burns up. Best buy knew this when they sold it to me as a "Floor Model", the "BEST BUY" repair man told me that they had repaired it already once before I bought it. I was ripped off by Best Buy, they told me it was just a floor model that was only out for a few weeks. It was a return because it failed and they just pumpped it up with refrigerant and sold it again to an unsuspecting customer.
Posted on Feb 07, 2007
    Problem Solver:
  • 5 Answers
I had similar problem with RS25555SL - freezer was ok but fridge not. Problem was motor on evaporator fan. After replacement everything worked fine. BTW - my was sold as SAMSUNG - but part was under MAYTAG.
Posted on Oct 07, 2010
    Problem Solver:
  • 14 Answers
Is the fan blowing air.....ck by holding peice of tissue in front of vent ?
Is the defrost timer workingl...ck by manually turning w/screwdriver around slowly till it clicks then the fan will stop running. Wait about an hour or so and the fan and compressor will start to run again if the timer is working. If you are O K to here, you will need to check the defrost heater and defrost shutdown thermostat, which require special tools and/or dismantling parts.
Posted on Nov 19, 2009
  • dradak1 Oct 07, 2010
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 10 Answers
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Posted on May 05, 2011
Samsung Refrig Compressor Problem
Can you tell where the hum is coming from?
Jul 10, 2013 | Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
The digital display on my rs2555sl Samsung stopped working and the fridge and freezer are not cooling. The fridge is only 4 years old. what could the problem be?
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Jan 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
My samsung ref rs2555sl stopped cooling. The temperature display for both freezer and fridge on the front keeps flashing. What do I need to do?
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Oct 02, 2009 | Samsung RS2578BB Side by Side Refrigerator
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer...
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Jun 15, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Samsung RS2578BB Side by Side Refrigerator Logo
3,729 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
