Question about Nokia N81 Smartphone
Nokia n81 8gb
Hiy i was downloading updates and my computer crashed now my phone wont switch on, i have had the battery and sim out still wont switch on can you help me please
N81
Posted on Aug 05, 2012
  • 435 Answers
It must because firmware problem. This could be due to partial installation of updates. It would be better to go to your nearest Nokia service center and get it repaired.
Thank You
Posted on Nov 14, 2008
Nokia E5 phone start-up failed. contact the retailer
the OS on your phone has crashed, that's why it is showing you start u failed.
Go to nokia.com, go to software and download nokia software updater. Download and install it on your computer. Connect the phone to your computer using a usb cord. Lunch the nokia software updater and it will install the phone, then another os will be download to the phone.
The phone should be okay, the moment the above is done.
Note that your computer must be connected to the internet when performing the above.
Also read and follow instruction on how to use the software updater on nokia site.
If the above does not work, it means you need another phone.
Good luck
Jun 22, 2012 | Nokia E5 Cell Phone
I have a nokia 5310. When I insert my Airtel or BSNL sim ( my old sim which i have used with this phone for the past two years ) it works fine, but when I use my vodafone or aircel sim ( which are my new...
hi
you are installed a security code when you are using your old sim cards
so if you wont to install a new sim card you have to know your security code
other wise
1) insert your old sim card
2) switch on the phone and back up all data
3) Connect your phone to pc using Nokia PC Suite and Data cable
4) make sure about your data
5) Download the Nokia Software updater
6) Update your phone software or reinstall if you have already latest software
if any doubt replay me
Link for nokia Software updater
http://www.nokia.co.in/support/product_support/phone-software-update
May 27, 2011 | Nokia 5310 Cellular Phone
The unlock switch wont work so i can look at anything of my nokia nuron
First switch off the phone then remove battery and sim card and memory card. then turn on the phone without this. try to lock.if it again unables to lock then insert the sim card, memory card and battery.
May 04, 2011 | Nokia 5230 Cell Phone
My phone is a Nokia E75. The problem is there is no way to switch it back from offline-mode to general. (as to what I found on the net it seems to be a well known issue but I didn't find a solution......
update your phone firmware to latest one,update solve many bugs and issues,you can download nokia software updater from nokia website europe.nokia.com
hope this will be help
Nov 27, 2010 | Nokia E75 Cell Phone
My phone got switched off while updating softwares. now it is not getting started what to do
My Nokia 6303 does not proceed forward from Nokia Title after switching on, rather it hangs after Nokia title and gives lights from its buttons but no button even switch on/off works until i remove my battery and insert again and then switch on but still same problem persist.kindly guide if you can
Jul 21, 2010 | Nokia 6303 Cell Phone
I got nokia 8500.i chared it last night and since then the light wont go off ( side button lock srceen but it wont et ligt off).used half battery in a day. tried switch on and off, sim off, rechared,...
did you try taking the battery and SIM completely out of the phone waiting 15 seconds and then reboot your phone.
sometime in my experience this solved customers weird glitches.
if not please update your problem further.
Mar 26, 2010 | Nokia 5800 XpressMusic Smartphone
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
N95 screen goes white
sounds like the software prob.most of these big multimedia phones crash and need to be updated by a repair shop.these have to be offical nokia updates.....but before that lift out your sim card and sd card and clean them,stick them back in and start it upagain.sometimes these get dirty
Sep 06, 2009 | Nokia N95 Cellular Phone
My nokia 6300 will not power up.
You can try updating the firmware using a Windows XP computer, which will also reset the phone to factory defaults (and thus probably fixes your problem).
Download the Nokia Software Updater from: http://europe.nokia.com/A4579163
Connect your phone to the computer using an USB cable, run the program and just follow instructions. Please note that you'll lose anything stored in the phone's memory (but not the SIM contacts !).
Whenever you still have warranty, you could take it to a Nokia Care center and have them update/reset your phone ...
May 06, 2009 | Nokia 6300 Cellular Phone
Nokia N95
U can get rid of this problem by resetting the ntire phone to factory settings, but before that make sure to backup all your database which is important as resetting will wipe everthing off your phone and bring to factory conditions.
the code u have to type is *#7370# and security default code prompted later is 12345 and u are done the phone will now reboot.
if the above doesnt solve your probem, download update manager from nokia website for your specific model and then after battery is fully charged with a sim inside the phone, attach a datacable and start the update, preferentially the update should be done with a laptop or a computer having backup power against power outage other wise your phone will get screwed.
the entire process known as reflashing will take around half to one hour depending on your internet connection.
the above should definitely solve all your problems
Apr 10, 2008 | Nokia N95 Cellular Phone
Nokia N81 Smartphone Logo
98 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
