Question about Panasonic Televison & Video
Im fixing a Panasonic NV SD 570 AM vcr . The problem was a jammed cassette tape and I changed the Left guide pole arm guide which had some teeth broken.Now when I want to put the cassette in it doesn't go in,I can sense that the cam motor isn't turning , but if I load it from an outside motor it ejects out normally but still then th ehead cylinder isn't turning , it turns a little left and a little to the right. i don't know if it is from the mode switch because I know that is is alligned in the right manner since it has a notch on it and it can only get in a single position on the main cam gear. thanks in advance.
    New Friend:
  • 99 Answers
Hi there.
U are definitely having a timing problem.
U have re align the gears and the eject mechanism, other wise it won't work.
Rifaa
Posted on Nov 14, 2008
Panasonic vcr model nv sd-300 auto eject when i insert cassette
Hi have u tried another tape it's rare but the tape is possibly Faulty it happened to me years ago... Cheers
Jan 06, 2017 | Panasonic Televison & Video
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a Panasonic NV-FJ600 VCR which ejects every cassette which is loaded , and the two guide rollers remain at the rear of the machine and do not move forward to engage the tape .
If you mean the guides are on either side of the head drum, and the carriage is in eject position, the mechanism is out of alignment. Re-alignment and re-timing may require a workshop service by a professional Panasonic agent.
The bad news is the likely cost(s) involved if parts are replaced.
The NV-FJ600A VCRs were good models a few years ago, one of the first 'super long play' series Panasonic launched.
They use the Z-mech series of decks. These are not impossible to re-align/re-time, unlike previous mech designs, but depending on the extent of wear/damage, can prove uneconomical for a budget VCR which would now be close to 10 years old.
Oct 18, 2010 | Panasonic NV-HD680 VCR
Panasonic NV HD630 is showing error f06 when the eject button is pressed. The tape cassette seems to be locked in and does not rise. I have removed the top. The tape is withdrawn back to the cassette....
You have a K-Deck mechanism. F06 means the mechanism locks after unload. The cause of this is the load motor or the carriage alignment.
If you enter "Panasonic K-Deck" into google you should find service information and a guide to getting the tape out - all free!
Oct 13, 2010 | Panasonic NV-HD680 VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic video recorder malfunction
It sounds like you need a service manual - it tells you how to remove stuck tapes etc.If you need a service manual for this model, which is helpful for checking things/disasembly/assembly, you can obtain a free one from:-
http://www.reptips.dk/Reptips/NV-FJ620.pdf
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
HO2 Error in VCR
I guess either the tape head is dirty and needs cleaning or you should email Panasonic with that question after reading the instruction guide's troubleshooting section.
Oct 17, 2008 | Panasonic DVD-RP56 DVD Player
Tape keeps ejecting - panasonic nvfj620
Is it only the Head cleaning cassette which keeps getting ejected, or is it happening with every tape you insert? Was the Head Cleaning Tape a little tight in the Cassette compartment? Did you have to put some pressure to push it in or did it come out with difficulty? From your symptoms, it looks like there is a gear timing problem with the cassette loading compartment gears. It could also be due to some obstruction inside. try shaking the VCR, and if you are hearing some noise, Open cover and check for foreign objects.
Apr 25, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
