My HP laptop will not power up or recharge. Fan comes on for a few seconds and then it quietly dies. Have checked and resited all obviously safe things to do that with but no go. Does it have a secret battery like old apple pcs that needs to be changed to make the machine live again? That is only similar problem I have ever had.
  • gillytaylor Nov 14, 2008
    Bro says we already tested them and got new PSU bits - any other ideas? Thanks by the way!
    Gill T
    Sergeant:
    Champion:
  • 331 Answers
Have you tried to replace the battery with a different one and see if the battery isnt at fault
as it has been seen that sometimes the battery backup of HP pavallion notebooks
reduces to very low values( just 30 sec of back up)
Posted on Nov 14, 2008
  • 59 Answers
Its either the carger or the battery. if you checked the charger and its good then it must be the battery pack which is dead and no longer holda any charge. so check the charger and try replacing the battery
  • 19,396 Answers
That is an hardware problem.
A thing that you can simply test is the RAM.
Remove vattery and unplug adapter first.
Open the RAM door, there you should find two modules. If there is only one you need to test with a replacement module.
Try removing one of them at time, and starting the laptop with one module only.
If it starts, then the module that was out is faulty.
A faulty motherboard will also give you the same problem, but that must be replaced by a technician.
  • 507 Answers
It isn't the battery. it is the connection from the powersource to the motherboard
read this
  • 734 Answers
Probably 2 problems 1. Adapter problem or
2. Laptop PSU (power supply unit) goes week or dam
It needs repair
Thank you for using FixYa
  • 790 Answers
Hello!!
Guess the problem lies with battery which u gotta replace!!
  • Kanth raj
    Kanth raj Nov 14, 2008
    But u can try changing the power cable once sir!!! And also try the power drain method once!!
    - power drain - unplug th cable, remove the battery, hold
    down th power button for 30-60 seconds and plug the cable back in
Hp g8ooo turn on for two seconds then goes of
Check charger power supply, are you getting voltage? Otherwise, I'd try to boot into "safe" mode probably f8. Try a Disk check. If problem continues, even in the safe mode I'd go to install disk and try a repair (without loss of data) option. Hopefully you have backed up just in case. If you have backed up and still have problems you may want to do a "fresh" install, but that entails reinstallation of all software. Not fun. Good luck. I find tomshardware.com quite helpful.
May 07, 2015 | HP Computers & Internet
I star the computer and shut down then go on and shut down
Possible overheating issue, check to make sure CPU fan is coming on and also resit memory and hard drive just to be safe
Feb 27, 2014 | Acer Computers & Internet
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
I was using it and turned it off and i came and turn it on and hp logo didnt appear on the screen it was only the lights and blank background please help me.is my sisters laptop and i took it without...
well. be sure the power is plugged in
then pull the battery out of the laptop
press the power button down
look at the little lights indicating power on .. battery charging and hard drive activity
if the power light comes on..
then the screen is the problem
if the hard drive comes on after say 10 seconds
it is definitely the screen
put the battery back in.. be sure it is in solid
put the power pack in the wall
if the battery charge light comes on
then the power is to the laptop and battery connections are good
so the laptop may have overheated...
wait five minutes
try to power it on again
if the fan does not power on...
it has a bad fan...
quietly set it where ya got it from then
Jan 21, 2011 | HP G60-235DX Notebook
MY HP PAVILLION 6262 LAPTOP WONT POWER UP, LIGHTS COME ON FAN STARTS, BLACK SCREEN. GOES OF AND TRIES TO START AGAIN AFTER A FEW SECONDS. HARD DRIVE, MEMORY AND SCREEN ALL CHECK OUT OK. IT ALL STARTED WHEN...
see if you can boot into safe mode as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu if that works, then try a system restore to before the problem started start>programs>accessories>system tools>system restore choose a date before the problem started
reboot
Mar 24, 2010 | HP Pavillion DV6227 Notebook
I have HP PAVILLION DV2000 LAPTOP IT SWITCHES OFF FREEQUENTLY BY IT'S OWN.WHEN I RESTART IT, IT WOULD COME UP WITH A BLANK DARK SHADY SCREEN. THE BATTERY CHARGING ICON IS SHOWING A MESSAGE (PLUGGED IN, NOT...
Could be overheating. Check if the fan is running all the time (it should, somtimes fast, sometimes slower, but always running)
Download CPUID's Hardware Monito *it's free" and install it from here:
http://www.cpuid.com/hwmonitor.php
After you install it, check the temperature of your CPU. It should never be higher than 70 C. If it is, then you have an overheating problem.
Check if you can see dust or lint inside the laptop.
If you want to clean it up to be on the safe side, do this:
1) Power down the computer and unplu the power cord.
2) Remove the bottom cover (you may need to remove the rechargeable battery too)
3) Blow compressed air into the bootom of the laptop and check that the fan can move easily
4) reassamble everything and power the computer back.
Mar 21, 2010 | HP Pavilion dv2000t Notebook
No power to computer. Battery cable recharger led lites up
If the cable and battery are good, you will need a tech. Taking apart a laptop is a touchy thing. If you are an electrician, you have to take it apart and test the wiring...but I warn you, parts in laptops are not made to come apart and go back together many times...connections are like paint, and wear of with a few reconnections and it's easy to permanently break it.
Jan 12, 2010 | HP Computers & Internet
Hp v6630em fails to start when the "on" button is pressed. It is connected to the power supply and the blue lights are illuminated. I can hear a whirring sound for a couple of seconds and...
This sounds like either a fan or CPU/motherboard problem. Either one is going to be expensive to fix, the fan less so than the CPU ($15-20 vs $100-$400).
However, before we assume that the laptop is dead, remove the battery and attempt to boot up just using AC power only. If the problem persists, put the battery back and remove the AC power, and try booting up just on battery. If the problem happens either way, it's the fan or the CPU/motherboard/.
I know this isn't what you wanted to hear, but that's what's happening. A decent local repair technician (not a big mass-repair place like Geek Squad) should be able to replace the fan with labor around $50 or so. The CPU/motherboard replacement will run at least $100-$150 in labor, plus cost of parts.
Obviously, try the fan first. You can pick them up on eBay and that way you won't be charged "extra" for the technician "finding" the fan for you. You should only have to pay them labor costs.
Obviously, if the fan doesn't fix the problem, it's the CPU/motherboard. At that point, I'd cut my losses with the fan (maybe even relist it for sale on eBay) and go buy another laptop. You'll pay $300-$500 just to fix it, or you can buy a new one for not much more, with warranty.
Hope this helps you out - I'm here to answer any additional questions you might have :)
Sep 29, 2008 | HP Computers & Internet
V2000 dead as...
plz check your power supply unit or checked it from a proffessional.Then post the result
Apr 01, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
