Question about Dryers
  • 833 Answers
Generally, manufacturers will rate the unit in terms of pounds of wash.  That goes for washers and dryers.  Most retailers can tell you what those ratings are.
Posted on Nov 15, 2008
Drum size for whirlpool wed55005Q0
This dryer is probably the WED5500SQ0. It's listed as a 6.5 cu. ft. capacity.
I hope this helps.
Sep 01, 2016 | Whirlpool Dryers
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Replace a belt on indesit dryer
Tools needed to solve the problem
(A)Standard screwdriver,New belt
1 Unplug your dryer to disconnect power to the unit.
2 Remove the screws that hold the dryer top in place using a standard screwdriver. The screws are located along the top and sides of the dryer. With older models -- 1996 and older -- the entire top comes off the dryer. For new models, the timer and console stay in place while the rest of the top comes off.
3 Remove the screws that hold the front panel and door in place using a standard screwdriver. The screws are just inside the door at the top front left and right sides of the dryer. The front panel on older models will move to the right side and on newer models the door will move to the left.
4 Remove the existing belt by pulling the idler pulley to the right. This will take the tension off the belt and allow you to pull it away from the motor pulley.
5 Install the new dryer belt by wrapping it around the top of the drum and allowing it to fall around the circumference of the drum. The grooves of the new belt should face down toward the drum. Rotate the belt around the drum to ensure there are no twists in it.
6 Connect the new belt to the motor pulley. On newer models you can access the motor pulley on the front underneath side of the dryer. Pull the idler pulley to the right and loop the belt around it. On older models you can access the motor pulley through an access panel on the back of the dryer. Pull the dryer away from the wall and remove the access panel using a standard screwdriver. Repeat the same steps as on a newer dryer to install the belt around the motor and idler pulleys.
7 Replace the front panel of the dryer and the screws that hold it in place.
8 Replace the top of the dryer and the screws that hold it in place.
9 Plug the dryer in and make sure the belt works properly before trying to use the unit.
Nov 07, 2011 | Indesit W 123 Front Load Washer
Is there something else i can use to replace the felt seal without buying a whole new drum on a maytag neptune model MDE9700AYW
On older maytag dryer's the felt seal wasa seperate part and not part of the drum..the problem is i do not know if the drum on the newer and older dryers is the same diameter they look similar in size but if it isn't exactly right may leave a gap where the clothes will get caught in...however the part number for that seperate felt seal is 314820
Aug 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
Have a bosch tumble dryer need to know how to fit the belt that holds the drum
Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Apr 13, 2011 | Dryers
Works but doesnt spin. Where is the belt located. I think that might be the problem.
To access your drive belt, you need to take the front cover off. Unplug the dryer first.
There should be 2 screws on the front cover in the lower front area. Remove the screws and tip the bottom of the front panel forward until the top clips are frree of the top panel. Be careful there is a door safety switch wired. You can disconnect the wire and set the front panel aside.
Look under the drum in the dryer and you'll be able to tell if the belt is broken or loose.
IF you need to replace it, you'll need to take the 4 screws that hold the front drum support/duct assembly loose from the dryer case. Once these are removed you can pull out the whole gray assembly and slide the drum out.
The new belt can be purchased online at if you want.
To put back in, you can put the belt around the drum and slide it back in. It should have a grooved side and a flat side on the belt. Put the flat side toward the drum. It routes around the motor pulley and a tensioner pulley. It may take a bit to figure out the routing, but the key is to put the belt into the indentation ring on the drum to allow you to get it around the pulley and tensioner... if you leave the drum sticking out of the machine about 8 inches, you can reach thru the drum and hook the belt in place, then slide the drum in and pull the belt out of the indentation and onto the larger circumference of the drum. You may have to twist the belt to get the flat side next to the drum.
You can then put it all back together...
Good luck... be patient and you can do it.
Sep 10, 2009 | Maytag HYG3460AWW Gas Dryer
In the frigidaire gallery gas dryer where are the fuses
I need to figure out the drum size of my Frigidaire gas dryer with model # fdg8970ew1 and serial # FDG8970E. I need to buy a new dryer and want to make sure I am buying the same size or larger.
Jul 27, 2009 | Frigidaire Dryers
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
Top Dryers Experts
