Question about Dell OptiPlex GX280 PC Desktop
I want to install windows Xp on Pendrive without harddisk Is it Possible If yes Give Idea On it
  • Anonymous Mar 06, 2009
    Yes I have same problems
Of course is possible to install Windos XP in a PenDrive. You have to use the bart PE Builder to create the directory structure and PEtoUSB to put this structure into the PenDrive. It's a really usefull windows.
David Lyons
http://www.ehtu.com
Posted on Dec 01, 2008
    Sergeant:
  • 306 Answers
No. You need 4GB just to install, environmental variables need a place to live that doesn't change and your paging file would eat up any space left. You could try Windows 3.1 or DOS -maybe even Windows 95.
Posted on Nov 14, 2008
  • 734 Answers
It is not posiable to install XP on pen drive, but if you need a cd like system boot from them without HDD with WinXP and serveral utility so contact me..
Will a latop work without main local disk
Yes, and can load from an external harddisk (if your BIOS supported to load from external harddisk).
there's nothing special if you run your computer without a harddisk.
Oct 28, 2012 | Microsoft Windows XP Professional
Mijn probleem is ik heb een acer aspire 7520 laptop als ik hem opstart boot hij steeds door,als ik windows xp wil instaleren kan hij de harddisk niet vinden.
Acer Aspire 7520 heeft een SATA-harddisk, kan Windows XP niet installeren. Lees deze
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Oct 19, 2010 | Acer Aspire 7520-5185 Laptop
Plz if you have any idea about installing windows xp over win 7
Yes you can install the Windows XP Operating system in your notebook. However, HP is not recommend to downgrade the Operating System. After installing the XP if you need any drivers please get back to us. We will provide you possible drivers.
May 21, 2010 | HP Pavilion dv6-1030us Notebook
Downloaded sp2 to my windows xp home edition when computer restarted i got a blue screen and error coad c000021a (fatal error code ) now i get disk boot failure how do i fix this
Harddisk might have some bad surface areas on it. This could possible due to power surge. Repair the HDD with harddisk tools. To do the repair without the tools try scandisk from the dos promt using boot disk. Reinstall XP with the sp2 and all the softwares that you use. Use repair CD that should do most of the softwares itself and install the others software with the CDs or setup programs on backup disk. Back up all the data before doing the clean install so that you can restore it after clean install.
Sep 18, 2009 | Computers & Internet
Power failure right when it gets to one
looks like a windows-related problem.
try if your keyboard works at all by entering bios but do not change anything. just quit saving no changes.
does it work?
if yes, possibly a windows error.
to check :
- try booting from a windows-cd(XP), not from harddisk, without going through install process, execute the repair process instead.
- reboot from your harddisk in safe mode.
everything o.k.?
if still the problem, and don't have any personal data you might loose on harddisk(hdd)
reinstall windows xp anew, but this time let it format the hdd fully, then go on installing a clean, new copy of win XP.
when still facing the problem, plse come again
Aug 04, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Can i install xp on pendrive ?
  1. Put the cd with xp on it in the cd rom
  2. plug your pen drive into your computer
  3. open "my computer"
  4. drag and drop the cd to the pen drive and it should copy the files to it.
Let me know how it goes.
Jan 05, 2009 | Microsoft Windows XP Professional
Removing windows xp without formating the harddisk
u need to boot from the cd rom & now u have format both of parttion c: & d then u can use on os
Aug 08, 2008 | Microsoft Windows XP Professional With...
Operating System is not detecting in my Laptop
kiran,
Windows XP not able to access SATA hard drive without driver. So it will not recognize your HDD if its of SATA interface.
  • If you can enter in BIOS setup, find out SATA option and if you find make it disable. Then try to install.
There are also other ways to fix this problem, if you want more help Just ask me.
Thanks
Iqbal
May 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Dell OptiPlex GX280 PC Desktop Logo
458 people viewed this question
Alun Cox
