Question about Canon ImageRunner 2016 Copier
Canon ir 2016 cannot/wont connect to computer via usb
I have a canon ir 2016. there is a usb port on the back and when I connect it to my computer....nothing happens. So I wanted to know if this canon ir 2016 can be used for printing.
  • 2 more comments
  • colinalb Jan 21, 2009
    Can you tell me which one I need....?, do you need the J1 kit only, or must you buy the J1 and the J2...
    Not exactly sure what either one of the kits do....
    I just want a network type card in the back of the ir2016, so I can plug it via a UTP connection into my LAN...
    Many thanks...
  • Anonymous Mar 23, 2009
    download standbay
  • oseim98 Apr 20, 2009
    the machine write DOWNLOAD STANDBY.Hw may i solve this.
  • kollector79 May 11, 2010
    Thank you for the response.ok so where can I get a printer kit j1 or j2 how does it look and where do I plug it in. Am sorry am abit ignorant on canon products
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
  • 421 Answers
You will need either the Canon PCL printer kit J1 or J2 if you want it to print (unless it's already fitted). If the copier is an IR2016J then it cannot be upgraded to a printer.
Posted on Nov 14, 2008
  • Adam Peake Nov 15, 2008
    Printer kit J1 will cost you £230 - £250 retail. The kit contains a pcb that has to be fitted into the back of the machine and a memory upgrade card. You then need to download the PCL software and install it using the Canon SST tool on a laptop. Quite a bit to do and you will need to find the firmware upgrade for the PCL kit from somewhere.
    This is the service manual which has some info about the kit etc: http://www.tradebit.com/filedetail.php/4...
    Habit-Forming:
  • 16 Answers
If you want to get proper information you can call at 1-888-924-2961 toll free number for canon printer support services. Technical Support For Canon Printer
Posted on Jul 26, 2016
Firmware for canon 2016
You need a special program in your computer called service tool,on which is firmware,Connect your printer with computer and download firmware
Jan 04, 2015 | Canon iR 2016i Black and White Copier
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
I have a canon ir2016 photocopier which can print documents directly from a computer if connected to it! I have connected it to my windows xp2 pc through a usb port but it is not detected at all. how do I...
As far as I know, Canon IR2016 is stand-alone copier. Printing is optional using Network connectivity. The USB port found at the back is for upgrading purposes only.
Sep 08, 2011 | Canon iR 2016i Black and White Copier
WONT DRIVER FOR IR 2016 V ERSION 60.02. PLEASE
my machine problem is display massage download softwear need help and wont driver for ir 2016 .thank
Jul 07, 2011 | Canon iR 2016i Black and White Copier
The iR2016 has a printer cable connection at the back. Why doesn't my iMac see this when I connect the cable via USB?
the USB port on backside of the iR2016 is ONLY for service support tool, cant be used as printer.
Aug 25, 2010 | Canon iR 2016i Black and White Copier
I cant complete the intallation of Ir2016 printewr driver-no usb port is detected
Do you have plain model with marking ir 2016 or 2016J or 2016i
Plain model does not have print option, network is optional and usb port is there for system upload.
Aug 09, 2010 | Canon iR 2016i Black and White Copier
Computer doesn't detect the CANON IR-2016J Machine, upon connecting the USB Cable. Assuming that USB cable in OK
the ir 2016 J cant be used as a printer without network function wich is optional. USB port is only for system software upload on these model.
Jul 26, 2010 | Canon Office Equipment & Supplies
Can not install the printer using usb port on canon ir 2016
Do you use PCL or UFRII drivers?
Try with PCL but there should not be a problems.
Have you try on another PC?
May 28, 2010 | Canon ImageRunner 2016 Copier
Canon ir2016 TROUBLESHOOT printer problem
Hi mate,
Prior to the issue you facing currently seem like ,
1)have u put the printer driver as default.
2)have u point to the correct printer port at the driver.
3)at the driver advance setting ;get the device status then reboot the machine .
GOOD LUCK MATE......Kindly RATE ME!!! Thanks YOU.
Sep 26, 2009 | Canon ImageRunner 2016 Copier
USB Port
To transfer video to your computer from the ZR100, you will need to connect the camera to the computer via the firewire interface. The ZR100 does not have a USB interface.
Jan 19, 2008 | Canon ZR100 Mini DV Digital Camcorder
4,661 people viewed this question
old marine
old marine
