Question about IBM Infoprint 1512 Laser Printer
How to refill printer ibm laserjet infoprint 1512
  • Jeff Weiss May 11, 2010
    What are you trying to refill in the printer?
  • 81 Answers
If you mean you need to refill the toner for this printer, i would not attempt to do it yourself. Seek out a reputable remanufacturer or supplier of the toner cartridge
Posted on Aug 22, 2009
Download cd
Your product is a bit of a mistery for me, IBM no luck then this at Ricoh http://www.infoprint.com/internet/ipww.nsf/vwWebPublished/supwg_infoprint-1512_en#h3/
Not sure if I am on the right track or not, so similar if not the same, Y/N?
Actually I went to another IBM site and seen that it is a Former IBM product, it's on there pointing to the link I posted.
Hope there's something there for you, cheers.
May 15, 2013 | IBM Infoprint 1512 Laser Printer
I want to set up IBM1512 on windows 7
I used an Lexmark E342 printer driver. It is the Lexmark version of the printer and the driver that is readily available for Windows 7.
Apr 20, 2011 | IBM Infoprint 1512 Laser Printer
I have a IBM Infoprint 1512 and on the display it says to replace photocon but it is printing fine. What is the problem?
Those photoconductors have a limited life and have to be replaced. The message is warning that it is near the end of its life and wants you to have one ready when it goes out. Most printers will prevent you from printing when it reaches the end of the service life, some will let you continue to print but you will get reduced image quality. Either way, you'll need a new one soon.
Feb 03, 2011 | IBM Infoprint 1512 Laser Printer
How reset photoconductor ibm infoprint ibm1512 thank you
The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here: http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US
Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
Jan 13, 2011 | IBM Infoprint 1512 Laser Printer
Infoprint 1512 prints blanks from int. and ext. print source
How to get on software to setup for printer , infoprinter 1512 ( Ibm ) .
tha for kind wondows ( wondows vista )
Aug 14, 2009 | IBM Infoprint 1512 Laser Printer
Refilled toner and now printer reads - 30 invalid refill
The toner used must be for a different printer. That error message is displayed when the chip on the toner is not the correct one for that printer. It may be a defective cartridge, or the incorrect model. Try to go back to the place you bought it and return or exchange for the correct one.
Jun 16, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
No installation disc
your drivers are available here: http://www-01.ibm.com/support/search.wss?rs=95&apar=exclude&tc=SRDUKD&q=psd1*&dc=D400&dtm
scroll down to number 5 if you have windows XP, number 2 for vista. this link will take you to the operating sytem specific page for your driver, scroll down again and choose one of the first two FTP buttons marked english, there are both the postscript drivers and the PCL drivers.
Installation Instructions
  1. Download the file to a temporary directory or any desired folder.
  2. Go to the folder where the .EXE package resides.
  3. Double click on the .EXE file to run the installation program.
  4. Follow the instructions in the pop up windows to install the drivers for your printer.
Apr 16, 2009 | IBM Infoprint 1512 Laser Printer
IBM Infoprint 1512 out of paper message
It could be a problem with the paper feed roller above the tray or a sensor problem.
It should be looked at by a service technician.
Jun 12, 2008 | IBM Infoprint 1512 Laser Printer
IBM Infoprint 1512 Laser Printer Logo
220 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
