Question about Epson C64 InkJet Printer
Epson c64 will not print
Replaced cartridges, unclogged printer heads still won"t print
  • 734 Answers
Uninstall the driver and then reinstall
Posted on Nov 14, 2008
Can you Help me unclog my nozzle? Epson Picturemate PM240. Head cleaning 3x not successful: no blue ink at all. Print cartridge is brand new and showing 100% full. It tells me to replace the print...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 18, 2011 | Epson PictureMate (C11C556001) InkJet...
I cannot get the yellow colour to print either as a test print or full copies. I have cleaned the heads, checked ink levels and even replaced the yellow cartridge again but with no success.
Try the following steps.
1) remove the ink cartride and ckeck for damages
2) remove the ink cartridge and replace it securly.
Else the ink cartridge is faulty.
Apr 20, 2011 | Epson C64 InkJet Printer
My epson c64 only print blank pages, everything else is normal
how dry it is
cartriges do dry out
even new ones
wash the botom and make sure they bleed
failing that the carige might be bent
Sep 16, 2009 | Epson C64 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
Won't print black at all
Sounds like the JEt for the Black might have clogged or the print head has malfunctioned.
Feb 11, 2009 | Epson C64 InkJet Printer
Epson c64 printer
If you have already done lots of head cleans with no result, and you're SURE you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
May 25, 2008 | Epson Stylus® C64 InkJet Printer
Won't Print
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson C64 will not print
well it is the chipset on the compatible cartridge. it is not good.
try another one ..
Jan 11, 2008 | Epson C64 InkJet Printer
C64 printer
Is this a New printer or a used one? what are the cartridges new or uses original or third party Did you follow exactly the Epson installation procedure? lots of question for you to come back with
May 24, 2007 | Epson C64 InkJet Printer
Will not print
Unfortunately, if you have replaced the cartridges and tried many cleaning cycles, then there is no solution other than replacing the unit. A good replacement would be the C88+
Mar 18, 2007 | Epson C64 InkJet Printer
Epson C64 InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
