How to change paper tray on pixma ip4000 canon?
    Problem Solver:
  • 14 Answers
There is a button I believe just above the USB port on the front of the machine. The picture is of a printer and there are two areas that will lit up. If the light is on the bar that is in the vertical direction, this indicates you are using the top feeder. If the bar is lit that is horizontal you are using the paper tray feeder. The Default is normally on the top feeder. Most people do not even realize there is a paper tray on these machines. They are hidden well.
To change tray settings simply push the gray button found under the picture of the printer with the vertical and hrizontal bars usually lit in green!
Posted on Nov 15, 2008
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
Red does not print, neither does yellow . have deep cleaned 3 times without changing anything Canon Pixma ip4000
plugged nozzles use a syringe and water to unplug and put paper towel under to catch residue and use canned compressed air to blow out and clean unit!! :)
Jul 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Paper won't go in straight
check paper quality (wight, adsorbed humidity etc,) change it and reduce humidity where you store anf use it.
Feb 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Paper not feeding
because of u r printer roller has been damaged so it cant pick up paper & also change the gear box of your printer
Nov 27, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA ip4000/paper jammed problem
Tackler- I dont think I have a solution but I know that the cassette should stick out about 5cm i.e. the cover just fits on nicely. I found with mine sometimes it needed a firm (but not hard) push in as obviously some sensor was not being tripped and it would just not pick up the paper in the tray. Have you tried using the top down feed? At least if that works you can print (and you can stack up a couple of pages).
Oct 22, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma ip5000
I had identical prob with a PIXMA IP4000. Eventually solved by turning upside down removing bottom feeder tray and gaining access to the four rubber rollers which pick up the paper. I rubbed each one with light sandpaper to roughen up the rubber, turning each one by hand trying to try to abrade all the surface. It did the trick.
Oct 03, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
628 people viewed this question
jasbo
jasbo
