Question about Acer Aspire 5600 Series 5630-6951 Laptop
Aspire 5600 hangs with battery inserted, without battery works fi
I have Aspire 5600 hangs with battery inserted, without battery works fine, I have XP version, it was fine earlier, but first it stoped responding to touch pad, then whole system hangs, it is not all the times, 2 out of 20 times it works on battery to, but without batterry no problem.
Kindly suggest me solution my mail rajesh58 at gmail
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
One of 2 things, youre battery might be no more good, i u left a dead battery lieing around for awhile they tend to lose there charge so maybe buy a new battery, but i suggest reformating ur computer using the hidden partion in the acer start screen, when u boot ur computer hold ctrl + f10 this should enable the acer e-recovery management to reset the computer back to factory defaults. Note that everything in ur drive c will be deleted so anything u want to keep should be moved to the drive D. if its not ctrl f10 then search acer e recovery and ull find the correct key combination to enable it
Posted on Nov 16, 2008
Where is the wireless button located on the Acer Aspire 5600, how do I turn it on
If there isn't a small button on your laptop, then see if any button on your laptop has a "blue-ish" colored icon that might be Wireless. Pressing FN and that button should activate it.
Jun 05, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
To hangs
The best guess is to buy some more ram(very cheap on ebay) and insert it into your motherboard, it is the reason why it hangs, what you could also do is downgrade to an earlier version of windows that requires less ram to operate.
Windows vista requires 2gb of ram minimum
Windows xp requires 512mb or ram
Windows 7 requires 3gb or ram
Hope that helps
Mar 23, 2011 | Computers & Internet
Touchpad and keyboard no respond
The problem for the Acer Aspire 3000 series is into the chipset battery, that comunicate to the PC through a serial protocol (probably I2C) to sent information, charge, status, etc.
Due to an ACPI bug, the battery module is not recognized by Windows. Bios upgrade doesn't solve the problem.
To solve the proble there are three ways:
- change the Hal driver to "PC standard"
- disable (not uninstall) the "Microsoft ACPI-Compliant Control Method Battery " and "Microsoft AC adapter"
- unplug the battery for 1 minute and re-plug it (with windows running).
The first metod work fine but Wi-Fi doesn't wok. All the rest of hardware yes, "Suspend" not possible, you must torn off the PC manally. Not Good!
The second is the right. It work only if your PC (HAL driver) is configured at "PC uniprocessor ACPI", see Microsoft documentation for help (HAL options after Windows Xp setup...).
The best way is to install a fresh Windows Xp, WITHOUT BATTERY INSERTED!!!. Windows configure it automatically in the right option.
After installion start Windows, important leave battery unplug,
then go to the device manager, expand "Batteries"; than disable "Microsoft ACPI-Compliant Control Method Battery" and "Microsoft AC adapter". It's fondamental to not disinstall them, otherwise windows re-install them at next boot!
Now you have a complete usable PC with ACPI enable (suspend, auto power off,...), windows does not comunicate with the battery, and the system doesn't freeze. The PC is also able to charge the battery and use it, the only unusable function is the battery status.
The battery infact is charged by hardware not by software. If you are in battery mode you can't now how charge remain.
I have an Acer Aspire 3005 WLMi, with the same bug and now i use it without problem.
Sorry for my bad english,
Stefano Bassi.
Dec 26, 2010 | Acer Aspire 3000 Notebook
Can i down grade my vista home edition acer aspire 5630 loptop to xp if so pls help
yes you can but before doing that if you have a valid warrantty on the system contact acer and tell them what you want to do and if its oki with them buy a genuine windows xp or which ever version you want from them or microsoft ...and if u do not care about the warrantty buy it from microsoft and do a fresh installation without talking to the acer guys if u have a warrantty and if u dont speak to acer and consult them before doing that the warrantty will get void
Dec 28, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery
Nothing to worry about mostly all the laptops do this,
Sep 10, 2008 | Acer Aspire 3680 Laptop
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
