Question about Dryers
Hello brand new dryer, went to turn it on, horrendous noise and looks like drum dnt turn , are they secured when new plz
    President:
  • 1,462 Answers
Dryers are not locked for delivery
Posted on Nov 14, 2008
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
Hotpoint aquarius ctd00
The noise could be .... the drum sometimes has stick on metal pads for balance or heat shields that will come up and start smacking on the cabinet of the dryer. Remove or lift the top of the dryer and turn the drum and looks for these pads. if one has lifted either glue it back or cut the part off that has lifted.
As far as the not drying part ..... it could be that the dryer is just getting tired and the heating element is gong bad or it could be something as simple as cleaning out the vent going out of the house. You can do this by disconnecting the dryer from the wall and blowing it out with a leaf blower or having someone come in and do it professionally.
Hope this helps.
Nov 25, 2013 | Washing Machines
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
Aug 02, 2011 | Washing Machines
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
My Maytag pye2200ayw has been working great until today when a horrendous squeak started. I've taken the front off but am still having trouble locating the origin of the noise. The two pads supporting...
remove the drum a look at the rollers, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 06, 2011 | Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
Scratching noise coming from dryer
yes the felt is cushion and it sounds like it might be the blower fan sometimes they get off balance or just simply out off wack and the blades will rub on the housing
Feb 18, 2009 | GE DBXR463EBWW Electric Dryer
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Drum wnt turn
If the unit is new...get a service person in.  Do not do anything yourself.
Nov 14, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Dryers Experts
