Question about Hotpoint TDC32 Electric Dryer
Drum wnt turn
New dryer, do they come secure as when putting on it wnt turn and makes horrendous noise
    Scholar:
  • 131 Answers
Bob is right,the unit may have been damaged in transit,this is a new unit & should still be under warranty,im sure they will be glad to come out & repair it or replace it(i would suggest you push for the replacement,or you will be starting out with damaged goods).hope this helps,thanx for using fix-ya & please rate all replys.
Posted on Nov 15, 2008
  • 833 Answers
If the unit is new...get a service person in.  Do not do anything yourself.
2yr old maytag maxima dryer gets louder and louder after run 30min. prob. repeats after cool down and running again. Vent is clean new pipe, no error codes. Sounds like a surging vibration.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Apr 06, 2015 | Maytag Dryers
I have a candy condenser gcc58onb it is making a terrible noise when it turns the drum turn s what is this?
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Feb 21, 2015 | Candy Dryers
My Maytag pye2200ayw has been working great until today when a horrendous squeak started. I've taken the front off but am still having trouble locating the origin of the noise. The two pads supporting...
remove the drum a look at the rollers, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 06, 2011 | Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
After putting on new belt there is a noise that is not the blower wheel
Most likely cause of noise is loosening or failure of the rear support wheels on which the drum turns. Check that both wheels are secure and tight.
Dec 08, 2009 | Maytag PYE2300AY Electric Dryer
Scratching noise coming from dryer
yes the felt is cushion and it sounds like it might be the blower fan sometimes they get off balance or just simply out off wack and the blades will rub on the housing
Feb 18, 2009 | GE DBXR463EBWW Electric Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
42 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
