Question about Mitsubishi HC900 Multimedia Projector
Projector turns off after about 30 minutes? What's wrong.
Can anyone give me an idea as to what might be wrong? I can use my projector for about a half hour, then the lamp suddenly turns off. When this happens, the power light is red and the status light flashes green. Do I need a new lamp? or what?
  • Timothy Sr Apr 30, 2008
    the projector turns of after about 1 minute of running and sometimes it won't stay on for a minute
    we tried to spray air into it to clean the dust out of it, but it didn't work
    we also tried to see if the cables weren't attached all the way but they were
Check to be sure the safety switch at the filter is not being tripped when the case and or the filter surround gets hot and expands. Thats what mine did.
Posted on Dec 22, 2007
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
1201MP Projector in my daughter's classroom. The power button lights up the blue buttons on the top, but the lamp does not come on. We changed the bulb, same result. After a minute or so (we thought...
Clean the filters. Make sure that the vents are not blocked. fan are working? Make sure the lamp door is secured, Projector manufacturers will make the projector inoperable if the door isn't secured tightly. Reset the lamp timer. email me at info@allprojectorlamps.com if you need a manual.
Aug 17, 2010 | Dell 1201MP Projector
Optoma H70 picture flashes on and off
This is how my problem with the power not going on started. I cleaned mine and it was running much better. I decided to give it a good cleaning, but now the power won't turn on. Try at your own risk as this could happen to you as well. Just a note, I have had mine for 4 yrs with the same bulb, just over 6000 hrs. I was lucky until now.
Mar 30, 2010 | Optoma HD70 DLP Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
I have recently bought a second hand 3M projector, and when turned on the screen shows half Blue (i think) and half Red and when used via the laptop the red shows through on the right hand side, can anyone...
first reset the settings to factory default. you may have to realign the lcd panels and make sure the panel ribbon cables are properly seated. otherwise, you have a main board issue.
Jun 22, 2009 | 3M MP 8765 Multimedia Projector
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Mitsubishi HC900 Multimedia Projector Logo
299 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
