Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Canon S400 Memory Card Error PNY 256MB COMPACT FLASH
Need to find a way to retrieve 800+ images. Help?
  • 44 Answers
If you have not formated the card you might try any of the file recovery software on the web (I have used Piriform Ltd.'s Recuva with great success)
Posted on Nov 15, 2008
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
Jul 20, 2009 | PNY 4GB Secure Digital High Capacity...
Canon powershot S400 will come on, but no functions will work. Won't even cut back off. After about 2 minutes get memory card error, than after another 2 minutes camera will shut down. Help will be...
Try inserting other compact flash cards, if the fault occurs with any card the camera can be assumed faulty. Sometimes the pins which connect to the card can become damaged when inserting and require straightening or replacement. You will need to have a service centre repair it for you. Good luck!
Apr 14, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Memory Card Error and colors turn pink with flash on
http://www.imaging-resource.com/badccds.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=29819
Aug 06, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
The clock button battery inside the camera has expired. Canon will fix this for free (or if you want, will send you a replacement battery with instructions on changing it out). Read the following recall advisory, then contact Canon at 1-800-OK-CANON:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Jun 20, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Pictures gone!
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for. Recommend the last program listed on this page:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
After you've recovered the photos and backed them up on your computer, recommend formatting the card in your camera (note that this will erase all photos on your card). Look for the "Low Level" format option in your camera's menus. A low level format should help prevent this from happening again.
Apr 19, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Memory Card Error-Won't take Pictures
Hi momincali - I posted a solution for someone that seemed to have the same problem as you. If you didn't see it, this is what I wrote:
I had the same problem on my PowerShot S400 as well as I couldn't reformat the compact flash when using the feature on the camera. The solution that worked for me was reseating a small battery (about the size of a watch battery) in side the camera. To get to it you have to take the case apart.
I found this solution by googling and typing:
powershot S400 E50 error
I'm not sure if this site will allow me to add the web link - but this link had a picture of the camera and where the battery is located.
http://www.pinoyhack.com/2006/09/14/canon-powershot-s400-fix/
I decided to try it, since I figured I had nothing to loose, becaues otherwise I'd be looking for buying a new camera. To my surprise it fixed my problem, but I do not know if this is a permanent fix. If you do try this - take note of where each of the screws come from. There were 4 different size screws around the case.
There seem to be a lot of complaints about this problem though.
Good luck.
Nov 21, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
Nov 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Problem downloading pictures from memory card
Hi flashlal - I have a Cannon PowerShot S400 and I had a similar problem which uses a compact flash card. I could only view a few photos and it seemed like the rest were gone. I verified that my photos were on the compact flash card when I installed it in my pc and navigated to the compact flash card (You can do that by double clicking on the "My compute" icon). Then double click to the directory to where your memory card is located and navigate through the files. I noticed that my photos were there because the file size was in the hundreds of kilobytes (700KB and up), but the names of all the files were corrupt - they had symbols in the name. I figured at this point I had nothing to lose so I did a "check and repair disk" on the compact flash. To do this: take note of the directory that your memory card is located in (it should be something other than C:). Once you know where your memory card is located, you go to your start button on the PC, then to run. A pop-up window appears.The command to repair your disk is "chkdsk /f", however you have to tell it the directory of where your memory card is located. For me my memory card was in the E: drive so I had to type:
chkdsk e: /f
Once it finished running I went back to the my computer window and navigated to my compact flash folders. I looked at my photo names. I had to rename all my photos by putting the extenstion of "JPG" back as the file type. Once I did this, I could then view my pictures. The only thing I lost was the added information that my camera puts on it like the date, time, and camera setting used to take the picture. I was fine with not having that because it was more important for me to retrieve my pictures.
Good luck.
Sep 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
