Question about Cakewalk pyro 5 Full Version for PC
Does Cakewalk Pyro 5 work easily with a USB turntable
  • lcdjws Nov 15, 2008
    Thank you, your help is very much appreciated. My turntable is a Digitech Audio
    Regards,
    John
  • Anonymous Apr 11, 2009
    am having a whole bunch of problem with this damn sofware. i installed it but i get no audio from my t.90 stanton on my pc
Yes I have the Stanton T.90 USB Turntable and Pyro 5 came bundled with it. It work well with the turntable. What doesn't work well is registering applications like Activating MP3 or Ringtones. Had to get Tech Support 3 times (they do not offer phone support on this product so it is a 2 day response to email). They told me to reinstall using a new provided serial number. That did not work. Not impressed.
Posted on Dec 18, 2008
    Problem Solver:
  • 13 Answers
Yes, Cakewalk Pyro 5 works well with a USB turntable. It has specific support for USB turntables. One example of a turntable that works well with it is the Stanton T.90 USB Turntable.
Posted on Nov 15, 2008
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
Cakewalk pyro 5.0 serial
Cakewalk Pyro 2005 Plus 1.1
S/N: cwpp171331246 MP3 Creation Activation Key: 90F2A7FF Video DVD Burning Activation Code:: FCF9A2F9
or
CWSP-5.00-834700-142248,
CWSP-5.00-834701-451782,
CWSP-5.00-834702-106549( 3 serials
hope it helps
May 16, 2012 | Cakewalk pyro 5 Full Version for PC
I set up to make a wav cd and get the message: "write error in volumn administrator." what do I do?
It sounds like the program is trying to access things it's not allowed to. Have you tried running it as an administrator?
May 03, 2011 | Cakewalk Pyro Audio Creator - Windows CD...
I purchased the Stanton T55 USB Turntable today,I put it together and I was told it would play with just the USB connection to my PC. Needless to say,I cannot get any sound from the turntable. Not...
You can get a cable to convert the two outputs from the turntable to a 3.5 if that will help. Amazon should have them. Picture below:
or
grubhead_9.jpg Also check your control panel and sound selection (IE SoundMax etc) to make certain the imputs are switched on or not set to low or on the wrong sound settings.
Feb 22, 2011 | Stanton T55 USB Turntable
Cant'r run pyro5 on windows 7. is there a solution other than buying new pyro software?
Yes, but it may be more expensive then buying the new Cakewalk pyro Audio Creator 1.5 ($40). The cost will depend on your version of Windows 7 among other issues.
From the Cakewalk site: "pyro 5 and the other versions listed above will not launch properly under Windows 7. They will not function at all."
The work-around is to run the software such that it thinks you are using an older version of Windows. There are a two ways to do this with one computer: 1) run a dual boot system with Window 7 and an older version of windows, 2) run a virtual computer with an older version of Windows inside the Windows 7 system using Parallels, VMWare or Virtual PC.
In most cases for either option, you need a licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate, you can get the virtual computer with XP for free. Download Microsoft's Virtual PC and then the XP mode package. Install them in order and install your Cakewalk software to the XP computer as if that is the only computer. The only issues can come up is that peripherals (like printers) can't be installed on both the real and the virtual computer and sharing files has to be done by saving to optical or other external media.
I'm not sure how much of a learning curve would be involved but there is a free audio editor available. See http://audacity.sourceforge.net/ for more information - the Win7 version is still in beta but works.
I hope this helps.
(Virtual PC http://www.microsoft.com/downloads/en/details.aspx?FamilyID=04d26402-3199-48a3-afa2-2dc0b40a73b6; some updates are also available.)
Dec 30, 2010 | Cakewalk Pyro Audio Creator - Windows CD...
Pyro plus does not work on windows 7
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 02, 2010 | Cakewalk pyro 5 Full Version for PC
Registration problems
To run as administrator in Vista, the Pyro website offeres the following instructions:
"There could be an issue with Vista's User Account Control. Right-click the Audio Creator shortcut you use and choose "Properties." Then click the "Advanced" button at the bottom of the window that opens. You'll be able to check "Run as Administrator" there. Click OK and from then on Audio Creator will run in admin mode when it's launched from that shortcut. You will then be able to enter your Serial and Registration Code."
When I tried to enter the registration code manually, the program would not accept it. When I copied and pasted the code from the email (no typing), the program accepted it. Good luck.
AGS
Oct 28, 2008 | Cakewalk Pyro Audio Creator - Windows CD...
The cakewalk pyro program will not write the tracks . its a new e machine . the program is 4 years old but worked perfectly in my old computer. can you help me ??
check the system requirenments of the old program- if made for an earlier version of windows do this:
uninstall it. then reinstall using the program compatability wizard found by hitting start-programs- accessories- program compatability wizrd- this will walk you throught the install and ask what operating system the program was originally intented for and aid you through and incompatability issues.
Oct 21, 2008 | E-Machines Computers & Internet
How do unlock the encoder.? For MP3. Do I have to buy Pyro. There is no Pyro included with my Sonar cakewalk product?
Most Cakewalk products include a trial version of MP3 encoding technology. For unlimited MP3 export in your product, you must purchase the Cakewalk MP3 activator
Aug 30, 2008 | Computers & Internet
Cakewalk pyro 5 Full Version for PC Logo
374 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
