Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Timer light blinking green/tv won't turn on
When I try to turn the Mitsubishi WD-62327 on, the green timer light on the front blinks green. And the tv doesn't turn on. I have tried to unplug it, in hopes that it will reset, but the same thing happens. How do I get the tv to turn on?
Thank you.
    Genius:
  • 1,139 Answers
Hello avtech,
Your diagnosis is correct and your suggested fix is correct as far as the manufacture says, however there is much debate on why Mitsubishi changed the DM module caps fro 1000uf to 680uf. by changing from 1000uf to 680uf you change the time constant of the charge and discharge of the capacitors (faster charge and discharge times). This would mean that the spikes that are causing the caps to fail could be nulled out during the fast discharge. The problem is you avoid the spike by hoping that it occurs only on the part of the time constant that is now part of the discharge time. The 1000uf gave you a slower TC, the 680uf gives you a faster TC. A lot of TV technicians who are also engineers agree that this works, but the cost due this method is not a good one, you still do not take care of the central problem which actually is sharp increases of voltage on the 12v rail, that these caps filter ripple for. There are actually four ways to fix this problem, One is the replacing of the caps as you have suggested, which until more data comes in, is deemed as the manufacture approved method (although not the best). Second, replace the caps as is (This buys you about 4 years of functionality until another replacement is needed). Third, replace the caps with ones rated a 1000uf but 35 volts (This one allows the ripple to be filtered a 1000uf, this provides better filtering action then the 680uf, and a higher voltage limit), which allows for higher positive voltage shift without destroying the capacitor.
Fourth is the most logical and expensive, use the proper filtering method, namely a chebyshev filter containing capacitors and choke coils set to provide 10 dbm of attenuation per L section.
The last would be the best solution, albeit the most expensive. In any event the method you gave to the customer was the manufacture suggested method. Good work.
Thank you,
Shuttle83
Posted on Nov 16, 2008
    Scholar:
  • 146 Answers
The DM moduel is bad. You can fix it by replacing 4 filter caps on the DM moduel. Do not replace them with the same type that is in there. You need to replace them with 680u 16v electrolitic caps. They are easy to find. Pull out the DM board, they are at the corner of the board and the tops of the caps are bubbled out a little.
Posted on Nov 15, 2008
  • 179 Answers
The wd 62327 doesn't have a DM module as it doesn't have the atsc tuner. are you sure you have a wd62327?
in a normal set
power:
Green Blink = μPC Initializing (after AC off/on) (1~2 sec)
get the error code by doing this: (and let me know)
Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The ” Power LED” flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is “34”, the LED will flash 3 times, pause, and then flash 4 times.
Posted on Nov 17, 2008
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi 72" projection TV I turn on and then turns off
If this this a LCD projection It may be a faulty lamp. It is a great idea to call the support center. they can walk you through it and advise you too.
Apr 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Vs-55707
Press Input and menu together on the TV control panel and hold them for 5 seconds see if it blinks a two digit code.
Oct 31, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
450 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
