Question about Eureka 411A Upright Vacuum
Eureka 411B Upright Vacuum
I couldn't find this vacuum listed, whether or not the 411A is similar though.
I took apart the brush housing part to clean it. There were 2 pieces that came loose. It some how keeps the body of the vacuum from falling down when it is upright.
It's a white rectangular bar like piece and a metal "V" shaped piece. I can't figure out where they go back in there. I've looked on the Eureka site at the manual, but no where on there can I see those 2 pieces to try to figure out where & how they go back in there.
  • blake_more73 Nov 18, 2008
    Mine is a Eureka 411 B. My cousin was the culprit that disassembled to unclog. I have it unclogged and ready to reassemble and like Amber, I can't figure out the place ment of the upright 'stop'/ same description of two parts as Amber. Vacuum now works but need the parts to stand vacuum up. TIA for your assistance. bud b.
  • ravgopal May 04, 2009
    Even I have the same problem. I opened the base section to clean, two loose part ('Y' shape metal clip and white color plastic sliding piece) fell out from its position. I tried lot to refix, but not sure where was it before.
    Any help will be appreciated. I have 411B model vacuum
    --Ravi
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Posted on Jul 23, 2009
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays diagonal and directly on top of the metal spring, round edge up, and aligned with the open ends.
Posted on Sep 22, 2009
  • johndubar Sep 22, 2009
    Correction! ...nylon piece lays parallel and directly on top of the metal spring
Eureka boss pro
go to a vacuum store and get help puting iy back together.
Oct 27, 2013 | Eureka 411A Upright Vacuum
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
How do i put the motor back in vacuum? the motor shifted when we were trying to clean it!!
I used to work for a manufacturer of vacuum cleaner bags, filters, etc., and we would wear out vacuums left and right. Unfortunately, once you remove a motor, especially out of a Eureka, the chance of you getting it back in are slim to none. Your best bet would be to either go to Eureka's website at www.electroluxhomeproducts.com, or, contact a local vacuum dealer and pay the $25 to $50 in labor to have a professional reinstall it. That price is a lot better than having to pay more than $200 for a new vacuum. Hope this helped!
Sep 22, 2010 | Eureka 411A Upright Vacuum
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
Eureka Boss Capture - bagless upright - green
HI
are you sure its the height adjuster?
More likely to be the bearings in the brush.
Rob
Feb 14, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
No suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Oct 03, 2008 | Eureka 411A Upright Vacuum
No suction with roller
how long have u had the vacuum and have u checked to see if it is clogged yet?
Jan 19, 2008 | Eureka 411A Upright Vacuum
Eureka 411A Upright Vacuum Logo
484 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
