Question about Radio Communications
Ut 40 and 50 tone squelch
I am looking for a schematic diagram of ut 40 and 50 tone squelch for my icom 28H mobile base and portable icom 2G.
Pls help help where can i get this diagram cause here in our place i cannot buy one cause there is no stock here.
    New Friend:
  • 109 Answers
Go to http://www.repeater-builder.com/icom/icom-ic-4ga-gat-ge-svc-man.pdf , there is a layout of the decoder in this pdf file. I hope this helps
73's de Patrick N5SLI
Posted on Nov 14, 2008
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
Icom m36 will not receive. Speaker makes noise with squelch all the way up but just won't receive anything including weather.
You may have the CTCSS tone squelch enabled so unless a station you're listening to is encoding CTCSS tones, you won't hear the traffic you're expecting.
Oct 28, 2013 | Icom IC-M36 VHF Marine Radio
Squelch not tight enough on the ic-a210
Not to sure what you mean, but may I suggest: join yahoo group specific to your radio Make/Model, there you will receive lots of in fo plus you can download manuals, schematics and other goodies.
I hope the helps you.
Regards,
Peter
Feb 01, 2013 | Icom Ic-a210 Vhf Mobile Aviation Radio
My icom ic v8 is weak on receiving...pls help
Is it week because the incoming signal is coming from further away or is it coming from down the street . Maybe the problem is on the other end,the incoming signal is not strong enough.Lots of reasons.
Jun 04, 2012 | Icom Ic V80 Vhf Handheld Two Way Radio...
I recently bought a new icom ic-41s from my paragliding instructor. When I bought it, he set it up for tone squelch as that was what we were using. Now I want to turn it off however no matter how many...
  1. Select the channel you want to adjust the CTCSS/DTCS squelch on.
  2. Press and hold the "Set Mode" button on the top of the radio for 2 seconds to enter set mode.
  3. Push the top button again several times until "C" appears.
  4. Push "Scan/Tag" to toggle the CTCSS tone frequency/DTCS code setting modes.
  5. Push "CH Up" or "CH Down" to set the desired CTCSS/DTCS code or remove the codes by rotating it to "0" or "OFF."
  6. When the tones are set as you wish press and hold the "set" button at the top of the radio again for 2 seconds to exit.
  7. Done.
Regards, Tony
Apr 30, 2011 | Radio Communications
ICOM IC-28H very low sound from radio even thought volume is max
I had a very similar problem on a hand held scanner. In my case the mylar speaker cone had separated from the voice coil. I found an exact replacement for under $4 at Allied Electronics.
Jan 07, 2010 | Icom IC-R10 Handheld Scanner
Squelch circuit
ok here is the awnser you are looking for you acn download the service manual here.
cbtricks.com go to the radio info section go to the g section look for galaxy dx radios scroll to your radio look for service manual, schematics and download what you are looking for.
Mar 03, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Radio Communications Logo
897 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
