Question about Bose Lifestyle 28 II System
THe unit just says Bose Lifestyle and nothing else happens. Remote doesnt work, I replug power and still nothing. It started right after we were watching a new DVD and it read disc unreadable. Any help would be greatly appreciated!
  • Anonymous Jan 28, 2009
    My problem is very similar. I have a one year-old Bose Lifestyle 28 system, and the system went dead suddenly - no system response, no remote control response. Unplugging the power unit for 15+ minutes and then re-plugging only results in a very brief flash on the system screen of "Bose Lifestyle) before it goes completely dead again. The system is plugged into an outlet with other electronic equipment, which have shown no symptoms of a recent power outage or power surge, so the Bose system seems to be the issue. I suspect the power module has blown somehow, but don't know if there is a serviceable fuse involved, or if replacement is the best answer.
Call tech support to see if they can help, they might set up a repair for you
Posted on Oct 28, 2007
My remote stopped working
First check the batteries. Then clean all of the connections. If still nada then check out the remote by pointing it at an am radio set to 600khz about 6 inches away and listen for beeping when you press any button. If nothing happens then the remote is trashed and needs to be replaced.
Jul 31, 2015 | Bose Lifestyle 28 System
No sound
Sometimes it is as simple as pulling the powerplugs of the system and then powering it up again. This resets the system and may get you going again. Also make sure that the cable between the center and the bass module is well plugged in. to be sure unplug and replug on both ends. If that does not work your unit needs to go back to Bose.
Mar 30, 2014 | Bose Lifestyle 28 System
I have a bose lifestyle 28 system purchased back in 2003. The remote broke when it was dropped on the floor (no longer functions). Is it possible to repair the remote or buy a replacement for this older...
Exactly how "broke" is the remote? (pictures help here, but if you don't know how to post one, or how to keep it under 150KB in size, then be as descriptive as possible in a REPLY to this post.
Feb 27, 2011 | Bose Lifestyle 28 System
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
LIFESTYLE 28 Series III System: i have unique problem. My TV is connected to Bose ...
i would try changing ports right at the lifestyle unit ...make sure the port is good
May 18, 2010 | Bose LIFESTYLE 28 Series III System
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Lifestyle 12 receiver vs lifestyle 12 II
yes will work just fine, a slight difference in the output gain from the control baord, but in almost all other cases you wont know the difference. just make sure especially if you intend to use the old cd unit with the new bassbox that if you connect the digital source to to (say dvd player) that you initially use bose remote to turn on bass baox and set volume.
Jan 17, 2008 | Bose Lifestyle 12 System
Bose Lifestyle 28 II System Logo
509 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
