Question about Cameras
Shutter not opening on canon powershot s40. screen is blank & images are black
  • 593 Answers
Does the lens have a physical shutter that you can see, like metal petals that open and close? On my camera, the aperature is made of petals that open and close to regulate the light and they close down completely when the camera is not in use. The petals are controlled by a small servo that, if non-functional, will completely "blind" the camera CCD. Many cameras use electronic shutters that have no mechanics and that would indicate a hardware problem that most likely cant be fixed without a new PC board or lens/CCD assembly..
Posted on Nov 15, 2008
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Jul 08, 2010 | Canon PowerShot S2 IS Digital Camera
Blank Screen on a Canon Powershot A610
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A610 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Jul 24, 2009 | Canon PowerShot S3 IS Digital Camera
LCD screen is blank and pictures are also blank
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Cameras Logo
134 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
