Question about OKI Office Equipment & Supplies
What's different of oki c7200 and c7300 cartridge?
  • 1 more comment
  • rickywu007 Nov 16, 2008
    Thank you for help,As I know the difference between C7200 and C7300 is the key position.the key is on the top of cartridge.but I don't know what's the exactly position.I am appreciated your help.
    Thanks, Ricky
  • Anonymous Mar 14, 2014
    oki c7200 error code 35
  • OKI Master
  • 4,338 Answers
They are different and can not be interchanged
C7200 work with C7200/C7400
C7300 work with C7350/C7300/C7550/C7500
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
Oki c7300 Fatal Error
all oki errors are fatal errors, there will be a 3 digit number that will tell what the error actualy is
Jun 02, 2014 | OKI C7300 Led Printer
Okidata C7300 Fatal Error 120
Service call 120: error
PU unit fan motor
1. Is fan in PU operating?
NO - Replace Fan motor.
YES - Replace engine control board (K7N).
2. Error reoccurs after replacing fan motor.
Jan 18, 2011 | OKI C7300 Led Printer
Toner sensor error
take out the magenta cartridge. and make sure the edges are clean. There are little metal pieces on the sides where the sensor reads the cartridge. Also, make sure the "lock" on the cartridge is locked.
Jul 22, 2010 | OKI C9300 Led Printer
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Phaser 7300 - refilling toner?
I have 4 colors toner for my last Oki C7200 they are so good (as good as genuine) and I have used them for many years till my printer gone. however please email me if you want them to ctcl_sz@yahoo.com
Feb 14, 2009 | OKI C7200 Led Printer
Oki c7300
Error 051 is a CU fan error.
It is solved by first replacing fan then the CU board.
I would call the seller or 1-800-OKIDATA
If you're comfortable with a screwdriver I would take the cover off
and look at the fan to see if anything is obstructing the flow.
Mar 24, 2008 | OKI C5200n Laser Printer
OKI C7300
Reload the yellow toner and re-seat the drum assy
check for foreign objects under toner/drum assy
make sure toner is locked and drum is seated correctly
also, check the small door on the left side of drum
if stuck closed, gently push open with small screwdriver
Mar 03, 2008 | OKI C5300n Led Printer
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
157 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
