Question about Whirlpool Washing Machines
Ink stains in my dryer drum!
My husband did a load of laundry and left a Bic ink pen in a pocket. After drying, there was ink all over the drum and the baffles. He tried to clean up and cover up the deed with Soft Scrub with bleach. Luckily I caught it before he scrubbed with the abrasive cleanser and carefully diluted it with water and cleaned it out, though unforrtunately I was gassed with the chlorine fumes in the process. Other than replacing the drum for about $250, is there a product or process that will remove the ink without damaging the enamel of the drum interior and the vinyl baffles? (A damp rag seems to smear the ink on the baffles, but not remove it, and has no effect on the enamel drum interior.) Thanks so much for your help and advice!
    President:
  • 1,462 Answers
Try something alcohol based - cheap gin for example or barbecue stsrter
Posted on Nov 14, 2008
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
Hello,i was washing my cloths the other night and a pen happened to be one of my pockets. The pen didn't explode in the washer but it did in the dryer. It ruined some of my cloths which is no big deal.The...
Hairspray is an excellent solution to the ballpoint pen ink problem. Buy the cheapest you can find and spray, let the spray sit on the spots for a few seconds and wipe with a paper towel. Keep doing this until the spot is removed. This also works on fabrics as well. As a former teacher, my red grading pen ruined several of my white shirts. I used my husband's $1.29 can of hairspray and saved over $100 in garments. He was pretty angry about my using all his hairspray but when I pointed out the money saved by not having to purchase new blouses, he relented. I keep a can of hairspray in my laundry room at all times.
Nov 04, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Pen ink stains on dryer drum, help!
use liquid solvent...thinners or maybe even some petrol from the lawn mower.... a little on a rag should do the trick,maybe some metho or even turps.
Jul 20, 2010 | Kenmore Elite HE4 Electric Dryer
Blue rubber glove in load stained dryer inside. How to clean?
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
Apr 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Ink stains vin my frontload gas dryer
Spray hairspray onto cotton and wipe off. Then wipe out the hairspray with a clean damp cloth before drying again.
Sep 24, 2009 | Whirlpool Dryers
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Ink pen broke in dryer
AVON Skin So Soft works on some inks. Use a white cloth and when you stop getting ink on the cloth it will be ok. Wash and dry a load of not so good towels and rags, old clothes to test for residue before using with the good clothes. Some staining may remain permanently in the drum.
Jun 08, 2009 | Whirlpool Dryers
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Washing Machines Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
