Question about Intel Motherboard
Want Compatible Motherboard
I am planning to buy a new motherboard compatible with my old devies.
--->1 GB DDR PC 400 RAM
--->512 MB DDR PC 400 RAM
--->PCIX MSI 8600 GT 512 MB Graphics Card
--->Creative SD 5.1 Channel Sound Card
---> p4
What would be the best possible motherbaord options to support these devices.
Intel is the one company I am looking forward to.
Motherboard should support upto 8 GB RAM.
Other suggestions like shifting to DDR2 along with motherboard also welcome.
Budget: 6000 INR.
Thanks & Regards,
Mak
  • 162 Answers
I would say you can take a look at ASUS, they have a pretty good rocking line of motherboards that will handle your stuff just fine.
Posted on Nov 14, 2008
What ram to use
The Dell E210882 system board is compatible with PC2-3200 (400 MHz) or PC2-4300 (533 MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Capacities compatible include: 128 MB, 256 MB, 512 MB or 1GB. The maximum installable RAM is 4 GB.
Sep 29, 2011 | Dell (E210882) Motherboard
RAM compatibility HELP
Yes this pc3200 is hardly compatible, because your motherboard is supportable of DDR 1 type RAM, Hence th PC3200 = 400 MHz, so you can add this ram to your PC, such that the ram which is between 266mhz to 400 MHz is absolutely a DDR1 type . please dont forget to vote for me.
Jul 10, 2010 | HP Computers & Internet
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
I want to add 1Gig Ram to istalled 512 Mb of Ram,Can I do this? NEC VERSA M160. Memory type DDR 533 Mhz PC2-400 200 pinSODIMM
Yes, of course you can do this with your own. The first things you should do are they:
You need to buy 1gb RAM which same socket to your old 512mb RAM. Be sure that the said RAM are compatible to your motherboard.
Dec 02, 2009 | Computers & Internet
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
Memory support confusion
Hello gu11ddu,
Here are the specifications concerning your question about your motherboard's RAM.
Memory Type grayquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz Max Supported RAM grayquestion.gif 4 GB
The key factors that are the most important when you select your ram is the MEMORY TYPE DDR SDRAM, 184 PIN DIMMs, and the SUPPORTED RAM SPEEDS 400 MHz and 333MHz. Your motherboard will support memory no more than 4 GB of memory, so yes you could use the 128mb modules, but you must make certain that they are DDR SDRAM types and 184 Pin DIMMs as this is what the manufacturer suggests is compatiable with your specific motherboard. The supported speed is also a suggestion, because this is the max speed that will work at it's optimal level. You can buy some ram modules that are higher, but they will clock down to the max speed allowed by your system. In other words, say for example you went to your local best buy or circuit city and bought the suggested memory type with the proper pin count and DIMM modules but they only had 500 MHz bus speed, then your system would clock the speed down to 400 MHz. With 4 128mb modules you are only going to get 512 mb max memory, because 4 x 128 mb = 512 mb so you will not be using all the available memory capacity that your motherboard can handle. If you wanted to maximize your memory usage you could buy 4 of the 1 GB memory modules or buy 2 of the 2 GB modules to obtain your max capacity. In your case buying 4 128 mb memory modules would not be worth it because you could buy 1 of the 2 GB modules and get better memory usage.
Another important thing to remember is that you should always use the same type of memory modules and never mix and match them with different ones as this could cause system crashes and problems with lots of memory errors. When going to a local store and asking a sales rep for compatible ram they will ask you what is the make and model of your computer and what your processor speed is because your processor speed also determines your bus speed because your ram will not operate above that speed it will simply clock down (if it is rated higher than what your processor speed is), with this information they will look up any compatible ram they may have in stock. Hope this answers your question and if you need further assistance please let me know.
p.s. your motherboard can support up to a pentium 4 class processor, but this may be different than what you have in your system.
If you do not mind, please rate my help as I would greatly appreciate it. Thanks
Sep 19, 2008 | Intel D915GAG Socket 775 Motherboard -...
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
Intel Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
