Question about Toys
Matel Barbie Dog Ginger....How does it work?
Where is the start button? I put in new AA bateries and it does not work.
do I need to replace the disk batteries?
2 Suggested Answers
SOURCE: How and where are batteries installed for spi-dog??
On its underside, there should be a screw that, when unscrewed, allows you to open its stomach and insert batteries.
Posted on Nov 16, 2008
My dog's SmartPets 4in1 Dog Training Shock and Vibration Collar has stopped working
It seems like your batteries have run out - you can buy new batteries from here The battery is very easy to change, the handset also runs on batteries but they are AA and can be purchased from your local store.
May 13, 2012 | Pets - Others
Instalation of AA bateries
There should be a battery cover in the bottom possibly with a screw, open it and replace the batterys, I will have to check the manual to confirm this..
Oct 28, 2008 | Sharp Wizard OZ-730
I just bougth a Barbie video Girl for my little Daughter, the problem is that on screen appears a memory card with and exclamation sign, no video has recorded yet, record, play and delete buttons dont work...
We just encountered this problem--Barbie's hard disk is full .You need to delete the files from the drive (even if you think you've downloaded them all previously). You need to tell your pc/mac to show hidden files (default setting is to hide them), then manually delete them. Not sure what started this problem, although improperly ejecting the Barbie drive might be the culprit, as this problem happened after we did this.
Jan 13, 2011 | Mattel Barbie Video Girl Doll Blonde
My multitester doesn't react
there are several reasons why the tester doesn't react..try to check these:
1. Check the safety fuse inside it.
2..The test lead set (the red & black wire w/ pin )
might have cut inside it,particularly in the part of
ends,near the pins/plugs.
3. The bateries might be o voltage and need to be
replaced.,or if the batery is good,just clean the
contact or teminal of the bateries.( a common
multi tester have 3 bateries, composed of 2 size
"AA" & 1- 9volts size.) these bateries are all
assigned to the "continuity"section of the tester.
(these are: X1;X10;X100 ; X 1K & X10K. )
so,if the tester is not functioning only in that
section,the first thing you have to check are the
bateries.Now.if you replaced the bateries with
new one but it is atill not working,then we go
back to my tip number 1 above.,that is to check
the test lead.
3. if you already finish checking the above method
and it still not working,then there is a problem in
the resistors of the system.
But, is your tester is digital? if it has no power: just simply check the fuse & batery..But if it has a power but not working when you use to test,you jst check the test lead or the selector switch becos the contact inside might be loosen.
Dec 03, 2009 | Skil 2100DAF Digital Angle Finder
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
I can not find the reset button on my DeWalt Radio.
take the two aa baterys out and the put them back this worked 4 me
May 19, 2009 | Dewalt DC011 AM/FM Radio
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
Barbie guitar reset button
The Barbie Diaries™ Barbie® Doll it what the doll is called. I found a number that you can call to get them to help you with this.I have also included the hours.
Monday - Friday spacer.gif grey_rule_px.gif spacer.gif Saturday
spacer.gif 9 AM to 7 PM Eastern Time 11 AM to 5 PM Eastern Time 6 AM to 4 PM Pacific Time 8 AM to 2 PM Pacific Time
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Good luck I hope everthing works out.
Sep 17, 2008 | Toys
Error message after installing software
First thing to check is to make sure your computer is compatible with the system requirements of the Barbie Girl. This sounds as if the Barbie Girl program is very old and you are using it on a very new computer. I've had this happen to me on vista with old windows 95 programs. Check your system requirements for that software, if it was designed for windows 95 it might not work. There might be a way to get it working in a compatibility mode which I can help you with, but first make sure your sys reqs are good. What version of windows?
Jan 08, 2008 | Computers & Internet
Toys Logo
429 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
