Transplanting HDD into new machine
Hi there. i got a new pc recently. its an AMD cpu and all the hardware is completely different to my last setup where the hard drive came from. As expected windows didn't cope with the change and i was presented with a blue screen. Is there a way to work around this? Some way that windows can scan for the new hardware and go from there? thanks in advance
  • brendon911 Nov 14, 2008
    thanks for trying guys. @ frenzy. the mainboard supports both sata and ide.
    @vikaspalia, the repair doesn't fix it. i still get the blue screen. i think the simplest solution is to just do a fresh install of windows
  • 258 Answers
Check if the mainboard supports the hdd you transplanted 'coz i believe that your hdd couldn't fit with the new system new mainboard supports sata
Posted on Nov 14, 2008
    Problem Solver:
  • 34 Answers
Its a simple problem. you may run windows setup again and run repair when asked to do so.
please do rate the solution
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
This desktop computer has involuntary shutdowns when started? A repair man said it's due to overheating. I read about a power supply switch set on 220v. Can you tell me more about this switch?
It has nothing to do with that switch, YOU MUST USE THE APPROPRITE VOLTAGE, EITHER 115V or 220V. Using the wrong value would completely fry your computer Components. Well especially if the voltage coming in is greater than that represented on the switch. This switch, switches between two different circuits within the Computer Power supply or PSU. One for 115V and another for 220V.
Your PC is overheating, it is shutting down to protect itself from permanently damaging itself. Ensure that your computer components are free of dust. pay special attention to the CPU cooler and Graphics Card cooler. Use a paint brush and Vacuum cleaner. If you are unable to do it then hand it over to a pro, as you have to be aware of ESD, Electro Static Discharge.
Click here to download hardware monitor.
Click here to download GPU-Z.
CPU temps should not exceed 45 degrees centigrade.
GPU temps should not exceed 65 degrees centigrade.
Thanks, thumbs up.
Nov 06, 2010 | HP Pavilion a6755y Refurbished Desktop PC...
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Blank monitor on startup
make sure the video card is secure
and monitor plugged in properly
does it shut down or you just get a black screen.
you can remove the card and if you have a different slot use it
then restart and see what happens
also are you saying you have dual harddrives
Jan 21, 2009 | Intel Motherboard
I have bought and installed a new HDD. I have partitioned it. I'm running windows xp setup. XP Setup begins installing windows gets completed...then system restarts and monitor looses display. this is the...
Hi there
I think it may be a graphics problem. May be the XP drivers are not compatible with your machine graphics card.
You could try this to solve it ...
From the web, possibly on another PC that's got the internet, download the graphics driver for your machine and save it to a USB disk.
Once the set up is complete, try booting into safe mode (press F8 on boot, then select boot into Safe Mode)
Now try running the driver from the USB disk (or copy it to C: drive first then run it).
Jan 09, 2009 | E-Machines (T2824) PC Desktop
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
