I NEED RAM
I have a PIII 850 with a p6bap-a+ amptron motherboard.User manual says that I have 3 dimm slots of 128mb ram tops , now I see on the net that I can have 768 mb ram?????? How can that be.....Please help I am in desperate need of ram!!!!!!!!!!!!!!!!!!
  • zouganeli Nov 14, 2008
    Thanks for the input , not very helpfull though !!!!
What is the maximum memory of motherboard model p4 vmm2 rev. 8.1
Posted on Mar 19, 2009
    Scholar:
  • 44 Answers
Hi zouganeli,
You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
Hope that helps
Take care,
Michael
Posted on Nov 18, 2008
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
What kind of memory can I use in my 6282-75u
IBM 300GL 6282-75u
IBM = Manufacturer
PC300 = Series
PC300 GL = Subseries
6282 = Machine Type
75u = Model
Intel Pentium processor or Intel Pentium with MMX technology, and max frequency rate ('Speed') is 200Megahertz. (200MHz)
Woo-hoo!
Two ram memory slots.
EACH slot can hold a maximum amount of ram memory -> 64MB
TOTAL ram memory amount for motherboard is 128MB (Woo-hoo!)
Ram memory is SDR Sdram. Commonly, but mistakenly, just referred to as Sdram.
Has 168 gold plated contact pins. 84 on each side.
Two Locating Notches on the bottom of the ram memory module.
(Two Side Notches. One on each side)
http://en.wikipedia.org/wiki/File:SDR_SDRAM-1.jpg
Non-ECC and 100MHz as shown above. (PC100) [ DIMM ]
I don't know if you can just use a 128MB ram memory module ('Stick'), in ram memory Slot 1, or not.
Me?
I would try it. May have to reboot up to 4 times for BIOS to recognize the ram memory. May NOT have to.
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Under the bold white heading in the black bar -> Technical manual
,click on the blue -> [+] Click for files.
It is a PDF file, and the HMM for the IBM 300GL-6282-75u Desktop PC.
(Hardware Maintenance Manual)
Cheap buy on PC100 - 128MB - ram memory modules,
http://www.weirdstuff.com/cgi-bin/item/23513
Regards,
joecoolvette
(PS.
You have a D.I.P. switch on the motherboard. SW1
Has 4 dip switches, numbered 1 through 4.
The positioning, (ON or OFF), determines the 'speed' support for the Processor.
Page 26 - PDF file page, Page 14 - Actual manual page )
Aug 24, 2012 | IBM (61H0382) Motherboard
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
A7s333 motherboard with 3 dimm ram slots 2 x 1GB pc2700
That board type does not show on the ASUS web site. I think that your problem may be incompatibility of the RAM with the board specs. Placing faster RAM on the board will not make it go faster.
Oct 24, 2009 | ASUS A7S333 Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Asus P3B-F Motherboard
Download a manual from the ASUSTEK website, I have read many forums related to issue's with ram and from what I have learned with the ASUS boards is that dependind on the bios and the model, each slot, for some unknown reason can only recoqnize a maximum of 128MB per DIMM slot? My board has 4. For example, no matter what I install for Ram the motherboard will only read 512, some of the forums on ASUSTEK reccomend reflashing the bios with an updated one, but now, with the age of these computers i find it difficult to find a Bios upgrade. It is ridiculas, the Bios should come from the manufacturer ready to handle the maximum Ram of 1GB, which is my case with the ASUS P3B-F Pentium 3 with a 850MHZ processor.?????????
Jun 08, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
Increasing memory in e-machine t2240
Hi slcdane 13. One thing with DIMM slots is that, first of all they are color coded there. Im assuming that you have 4 DIMM slots and two of them are one color, and the other two are another color. What that means is that is if One DIMM slot has a RAM module of a certain capacity, then the other DIMM slot of the same color has to contain a RAM module of the same capacity as the first module. Now i am assuming that you have more than two RAM modules and More than 2 DIMM slots. HERE IS AN EASIER EXAMPLE
Lets say you have DIMM slots 1, 2, 3, and 4. Slots 1 and 3 are yellow, and slots 2 and 4 are red. Now lets say you also have 4 Ram modules. 2 of them are each 2 Gigabytes ready, and the other 2 are each 1 Gigabyte ready. Now lets say you take one of the 2 Gigabyte RAM modules and you place it into DIMM slot 1 which is yellow, what this means is that you have to place the other 2 Gigabyte RAM module into the DIMM slot 3 which is also yellow. The remaining 1 Gigabyte modules will have to go into DIMM slots 2 and 4 which are red.
Now do you get it? Same capacity modules have to go into same color slots. Now try it and see.
Dec 31, 2008 | E-Machines T2240 PC Desktop
Max ram ?
Max -> 768 MB (3 x 128MB)
see this link:
http://www.memoryxxl.net/index.php/cPath/2293_2294_34196
/category/dfi-cb61.html
RAM Specifications: Standard RAM: ECC and non-ECC, Unbuffered and Registered, Chipset: Intel 440BX Maximum Ram: 768MB Steckplätze / Slots: 3 (3 banks of 1)
Dec 25, 2008 | DFI CB61 Motherboard
Can you expand the memory on a Systemax Intel SIS651 System
Your motherboard is actually a Foxconn 651M03.
According to your system you have :
512MB DDR333 PC2700 Non-ECC Memory (512MB x 1)
(One stick of 512MB)
The motherboard manual says this:
System Memory
Two 184-pin DDR DIMM slots
Supports PC1600/PC2100/PC2700 memory
Supports 64Mb/128Mb/256Mb/512Mb technology up to 2GB
(This means you can have a total of up to 2 Gigabytes of RAM)
If you upgrade your RAM, you will need to make sure that you get the correct type.
If you want to keep the RAM you have, you will only be able to have 1.5 GB of RAM because you only have two slots to work with. If you want to upgrade to the full 2 GB, you will need to buy 2, 1 GB sticks.
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
