Question about JVC XA-HD500 MP3 Player
My playlist is not goign back to the way i had it before and i dont knwo how to fix it
My playlist went to this random way, i want to set it back to the way where it is in order by artist. how do i get it bac kto teh way it was? this only happens whenever i add new songs on
0 characters
1 Points
Playing songs in order within playlists
Create a playlist on your itunes first and place them in the order you want it played and then add playlist to your ipod.
Jun 30, 2009 | Apple iPod MA446LL/A MP3 Player
Random play feature
Try going in to your player and creating a playlist.Go into your player through " My computer". When it brings up your main folders, right click on the music folder and click create playlist. All the songs you have will be bunched into one playlist.
Then while your player is paused, hit mode, scroll to the playlist you created and then set it to random play from there. Should work.
Dec 29, 2008 | GPX ML648B MP3 Player
New Ipod Shuffle is not loading songs
Generally you do not have to change the drive letter. There is a 'shuffle restore' program from Apple that you can download for free. Using this to restore your iPod will set it back to factory conditions. Do you have the latest version of iTunes on your computer? If not, you might want to try that also. Have you tried dragging your playlist into the Shuffle? I find that it helps with my shuffle to create playlists and have it fill out of them. That way I can change the playlist every day. Works for me. Hope that helps.
Dec 23, 2008 | Apple iPod shuffle Second Gen. Silver (1...
2 problems: (1) battery (2) skipping songs on playlist
There is a random mode - check the menu settings to see if it has been activated. Alternatively, you coould have downloaded fixed-term license songs.
Dec 04, 2008 | SanDisk Sansa e250 MP3 Player
Adding songs to existing playlists
The playlist created on this device is what I find to be really crappy. I've tried it and songs just seem to appear randomly. For this sake, don't use the playlist. Highlight every song that you want in a group in a (like in a playlist), then right-click then click properties. Go to the details tab and change the 'Album' field all at once to what you would like to call your grouped 'album'. Then when you safely remove the device, you can get all your songs in the same album!!!!
Jun 27, 2008 | Samsung YP-K3 MP3 Player
Shuffle seems to play same songs
The shuffle feature shuffles songs randomly - no way to change the order.
On the Sansa Clip, you have to make the changes to the song order in Windows Media Player first, before you transfer the playlist to the Sansa, using the advanced tag editor function; change the track number. If you have already transferred the song(s) over to the Sansa, you must delete the songs on the Sansa first, or else it will not accept the playlist transfer with the new track order. You can always go back and change the track numbers that are stored in your WMP library after you have transferred the playlist to the Sansa.
-Tha Mp3 Doctor
Jan 25, 2008 | SanDisk Sansa Clip MP3 Player
Removing random play setup
try menu then system.
i think that it is in there. I would go further, but am afraid it will do it to me. I too had that same problem. Good Luck
Jan 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Remove random play
go back all the way in the menu till you get to the begining and select music library, then go back to play mode and select normal
Playlist Problem !!!
The Sansa m200 series can only create playlists in MTP mode. on the menu go to settings>USB. There are two options MSC and autodetect. Once in autodetect your sansa should say MTP when connected to your PC. In this mode you should be able to add playlists without any trouble.
Hope it helps
Nov 23, 2007 | SanDisk Sansa m240 MP3 Player
Iriver X20- playlists and videos
yeah, basically all i did was change my settings to MTP.
then i went into internal hardrive (just in normal usb mode)
i selected the songs i wanted and right-clicked (make sure to do this one one of the songs you selected) in the options that come up it should say "create playlist" (in bold) i clicked that, it wouldn't let me rename the playlist... but it worked fine... and now they come up in the right place, i didn't even use Iriver plus 3.
Nov 22, 2007 | iRiver X20 MP3 Player
JVC XA-HD500 MP3 Player Logo
Top JVC MP3 & Digital Media Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
sonic boom...
sonic boom...
mac colar
Are you a JVC MP3 and Digital Media Player Expert? Answer questions, earn points and help others
